GL 1100 Cut, weld, wrench then ride
- AstroWing
Re: GL 1100 Cut, weld, wrench then ride
Getting the shape right on things like this usually takes a few tries.
Have lots of bikes... need one more.
- AstroWing
Next, I'll transfer this pattern to some 1/4" plate so I can weld some tubing for the intake. I will most likely make the water outlet round for braided hose.
- AstroWing
Still time to go with fuel injection, just can't justify the cost of an ECU. Any ideas?
The cost of FE is not really the ECU hardware but the software. Any can ECU would do good, but they are not easy to recode so that is where it gets expensive.
Remember this process needs no business case as it is a hobby. The cost of the ECU is for entertainment and the bike is a byproduct when you are done. Does that help with justification???
- AstroWing
Guess what I was doing when this thought came to me?
- joedrum
great thing to try ...hott doing it ...i always thought it was the way to do single carb
1979 1000
- irishcarbomb
Checkout microsquirt. Its what i plan on using. I think its around $350ish, then youll need all the associated hardware and a laptop to tune with. The software is free.AstroWing wrote:Still time to go with fuel injection, just can't justify the cost of an ECU. Any ideas?
Sometimes crappy ideas work out.
- CrashDown
I just finished a body restoration for one of these. You can see the pics on my facebook page linked below.Hamminahammina wrote:Cool!...subscribed. I was riding to work the other day thinking about how cool a GL with a relocated gas tank with dual webers would look. You could load up the visual mass to the front of the bike, kinda like this
well, that's what I was thinking about. Excited to see your progress
You're way more brave then i am to start cutting on a frame like you are. Hats off!
- AstroWing
I sent an e-mail to Microsquirt, thanks for the tip. It took me over a year to build my last bike, 3 months into this one and I am still trying to decide, Carbs or FI? Went to Motec and contacted Kinsler, the FI price tag was over $5,000. I get a tip yesterday and it looks like less than $500. This is why my builds take so long, I don't mind changing directions.irishcarbomb wrote:Checkout microsquirt. Its what i plan on using. I think its around $350ish, then youll need all the associated hardware and a laptop to tune with. The software is free.AstroWing wrote:Still time to go with fuel injection, just can't justify the cost of an ECU. Any ideas?
"If I knew then, what I know now, I would have made a different decision" Well, I learn things everyday! Thanks!
Liking how you are sharing your thoughts. I planned on a braided stainless hose conversion on an engine, the stock water tubes look rather, well, plumberish. lol
- bonneblktrk
Thats a good idea to switch the water pipes to hose. Gain a little space on top of engine by rerouting hose. More room for a blower manifold in my case.
Has anyone checked in using a used FI off a modern bike to retro fit to the GL
1975 Goldwing Build "8 pounds and 40 stone"
1998 Honda Super Blackbird
- AstroWing
Thanks, I really appreciate all the comments.sunnbobb wrote:Liking how you are sharing your thoughts. I planned on a braided stainless hose conversion on an engine, the stock water tubes look rather, well, plumberish. lol
Yes, I've got a pretty big pile of parts I don't expect to need. I think the braided water hoses will be a clean way to go. Should be pretty simple. I will keep all the notes so I will be able to help others convert their GL's I don't plan to use the stock radiator, but I'll keep those records as well so someone could convert easier.
I may need a little help figuring out if the small water hose coming out of the block, under the thermostat is a bypass or steam/air bleed?
- AstroWing
Thanks,CrashDown wrote:I just finished a body restoration for one of these. You can see the pics on my facebook page linked below.Hamminahammina wrote:Cool!...subscribed. I was riding to work the other day thinking about how cool a GL with a relocated gas tank with dual webers would look. You could load up the visual mass to the front of the bike, kinda like this
I really like the look of that Moto Guzzi. After my last build, I made a mandate for this build. Every straight line I can control, will match: the ground, the forks or the rear shocks. Much easier to say than to do. Not sure brave is the word I would use to describe my Sawzall work, Masochist seems more accurate.
- bonneblktrk
We were also thinking about a different radiator. Maybe something from a sportbike or sport-tourer. I think some Hondas have radiators on the sides under the side fairings. They might be better being aluminum. Also heard of someone using a oil cooler plumbed as a radiator.
