Dream Weaver: Stock 1975 GL1000 Antares(red) Restoration
OO7EDDY
Re: Dream Weaver: Stock 1975 GL1000 Antares(red) Restoration
Love that color! As far as signals go...make sure that the little connections inside the sockets are not missing or broken, that will cause the issues you are experiencing.
1977 GL1000
1978 GL1000
1979 GL1000
1978 GL1000
1979 GL1000
- BigDub
thanks! any specific connectors? reserve lighting unit.
1984 VF1100 Flat Black Saber
1981 GL1100 Flat Black Bagged aka my pickup
1976 MR175 farm/trail bike
1975 GL1000 Antares Red
OO7EDDY
Just the little brass nubs in the bottom of the signal light sockets.BigDub wrote:thanks! any specific connectors? reserve lighting unit.
1977 GL1000
1978 GL1000
1979 GL1000
1978 GL1000
1979 GL1000
- hacksaw1945
Bike looks great!! good thread \
Hack
Hack
1977 Honda GL 1000, 1982 Honda GL 1100I went naked, 1976 Honda LTD rough long range project, 1945 Indian Chief, 1947 Indian Chief, 1948 Indian Chief, 1958 Cushman Highlander, 1959 Cushman 3 wheel Mailister, 1966 Triumph TR6,
- BigDub
Thank you, sir! That means a goodly bit coming from someone with your resume.
These bikes have way too many connections, so any number of them can drop the available voltage and render the blinkers to no blink. Try running checking the voltage and see if you have 12 volts to them.
- BigDub
thanks will do......
1. i have right side marker/turn signals "ALWAYS ON"
2. i have the left side markers "always off"
3. right signals drop with right turn activation however not blinking
4. if the engine is revved and the left signal is activated "sometimes steady blinker action.
conclusion: will check connections with voltage meter. also, idk if the lights should always be on as the headlight, or always off.
