Yep. They screw right onto the end of the plug wires (unscrew the old ones first) Hint: there are 5k Ohm resistors in each plug connectors, so DO NOT use resistor plugs.
And So It Begins - A GL1000 Resto
Re: And So It Begins - A GL1000 Resto
And do yourself a favor and trim a good quarter inch off the ends of the wires before installing the new caps.
- BruteSquad
gltriker wrote: ↑Fri Jun 11, 2021 4:56 pm Don't waste energy cleaning those corroded spark plug cap terminals.
Buy 4 new spark plug caps.
NGK XD05F.
Ref. NGK #8072, for your local auto parts counter folks.
Buy them local.
NAPA and similar sources have them in their catalog.
5 bucks each is average price.
Great, thanks for the advice. Pretty sure I have resistor plugs previously purchased. Can I just remove the resistor like I saw somewhere (Randakk's maybe)?Whiskerfish wrote: ↑Fri Jun 11, 2021 8:22 pm And do yourself a favor and trim a good quarter inch off the ends of the wires before installing the new caps.
- BruteSquad
Yes, my plan is to redo much or all of the harness. There are so many splices from the vetter fairing and excessive number of lights and who knows what other barn jobs.desertrefugee wrote: ↑Fri Jun 11, 2021 5:20 pm From the look of it, unplugging and thoroughly cleaning EVERY SINGLE CONNECTOR on the motorcycle would be time well spent. If not, you will be chasing gremlins in the future. Perhaps on the side of the road in an unsavory part of town...
(Seriously, spend some time on sprucing up that harness (not the least of which will include getting rid of the wire nuts!)
Better to be proactive than reactive. That one shows the result of years of neglect. Needs love.
You can, but are limited to the more expensive plugs after that. You can replace the resistor with the same length copper tubing or some solid copper wire.Great, thanks for the advice. Pretty sure I have resistor plugs previously purchased. Can I just remove the resistor like I saw somewhere (Randakk's maybe)?
- BruteSquad
Over the weekend I did some more organizing to make sure I have everything I need. Brownie points if you know why I bought this:
Took the old valve covers/gaskets off to take a look.
Looks fine to me. Went ahead and adjusted the valves and put on the replacement covers and new gaskets
They are dechromed and need a little polish. May end up painted but not sure about color scheme yet. I got these from Brian Crow (Rogue1000) years ago. I went to look him up and was saddened to find out about his passing. I never met him but I bought these covers and a set of carbs from him. He had no reason to do so, but he threw in a bunch of useful freebies for me, a total stranger. He was just passing on his love for the bikes. And from reading his memorial page he had many friends and was a great guy. Hopefully a little of his spirit can live on in this build. Ride on, Brian.
It's about 2ft long, Tygothane. I have a new fuel filter and fuel line so I don't think it's for that. Took the old valve covers/gaskets off to take a look.
- BruteSquad
Is this the stock regulator for a 77? Seems aftermarket but not sure.
- NotSoLilCrippseys
Can't answer the question about the regulator, but I'll take a stab at the hose: I think you might have bought it to run from the brake fluid reservoir to the rear master cylinder?
In the Stable and Ridable
1976 GL1000 (Original Sulphur Yellow) - Needs a tag and insurance but ready to ride
1978 CB550K - son's cafe
Sold
Sold
Good guess, but the 1000's have the reservoir mounted directly to the rear master, unlike the 1100's...NotSoLilCrippseys wrote: ↑Wed Jun 23, 2021 9:31 pm Can't answer the question about the regulator, but I'll take a stab at the hose: I think you might have bought it to run from the brake fluid reservoir to the rear master cylinder?
- robbie202
Stock regulator 77
'77 GL1000
'03 Sportster
2020 KLX 250
'03 Sportster
2020 KLX 250
- BruteSquad
Mine's a little more faded and dirtier but looks the same otherwise
- NotSoLilCrippseys
And a noob reveals his ignorance - again. I learn a few things about one model and fancy myself knowledgable. Alas.Track T 2411 wrote: ↑Thu Jun 24, 2021 6:58 amGood guess, but the 1000's have the reservoir mounted directly to the rear master, unlike the 1100's...NotSoLilCrippseys wrote: ↑Wed Jun 23, 2021 9:31 pm Can't answer the question about the regulator, but I'll take a stab at the hose: I think you might have bought it to run from the brake fluid reservoir to the rear master cylinder?
Sold
Sold
- BruteSquad
Had a little time to look at some of my electrical work that needs done. I need to replace a connector but want to make sure I have the right size. Does anyone know the gauge of the wires that run off the solenoid to the ignition switch and rectifier (red and red/white wires)?
- BruteSquad
Well, didn't get much time during July but finally got some time over the past week and made some progress. Got my electric patched up. Won't know if there are any gremlins til I get it running but everything is connected. Also put in my water pump and got the transmission/water pump cover back on. Took a lot longer than I'd hoped but was going fine. I was about finished and that's when I ended up snapping one of the bolts. It was giving some resistance before it was even seated and snapped about half way in. How screwed am I? Can a left handed bit get that out of there? Any other tips? I'm worried I'll have to pull the engine to get it out. It's one of the one's blocked by the frame.
IMHO, pulling the engine is easier than working around a frame rail. Sometimes a left-hand bit (a good one) will work, sometimes (although rarely) an EzOut. Often taking the cover back off will give you enough to grab.
