I would like to make some eventually, but these work nicely.
I am on a zero budget so I built mine this weekend. Almost everything that is custom I built in my garage. These are my rough starts. I need to get them all purdy an all.
1982 GL1100 Silverback
2004 Roadstar For Sale
so, are the pickup tubes just open in the tank? now i'm interested. any more pics?
Yes, the tubes are just open in the tank, I was going to try to make some screens to put on them, but I read that the Por15 sealer can clog them up. I think my setup will keep sediment that builds up in the bottom of the tank from entering the fuel lines. Here is a quick sketch that I made.
Fuel Pick Up.jpg (24.69 KiB) Viewed 799 times
Sorry, I thought I took more pictures of the tank project, here is one before I treated the tank. It shows the pick up tubes a little better.
I cut the handlebar mounts off my stock triple tree with a hack saw and then ground them down with a flap wheel on my angle grinder until I thought I was close to breaking through (they are cast and are hollow underneath the handlebar mounts). I then sanded them down smooth, then bead blasted and polished them. I opened up the gauge mounting holes to receive the choke and a green light (the green light is a filler, I still haven't decided what to hook it up to, any ideas?) The stock ignition wasn't going to work with the scheme so I found this barrel key at an electronics store. I like it because the key can be removed in the on position so my keychain doesn't scratch up my shiny triple
My stock master cylinder hit the fork tube with the new clip-ons so I found the one I have on ebay and gave the top cover the polish treatment.
Here is a picture that might make it a little more clear.
That is really inspired stuff man. I hope you live by the adage that "Imitation is the highest form of flattery", as I prefer that over being called a "plagiarist".
So, any know if the control from the earlier bikes will fit an 81 Wing? They changed over to plastic housings in the next gen wings apparently, and I'd prefer to polish the housings like you.
Nate
"It is better to remain silent and thought a fool than to speak and remove all doubt."
-81 GL1100 (work in progress)
-98 KLR650
-00 Sportster 883
-09 C14
Beautiful job. This is the first time I've seen the thread.
Could you post a vid of the bike running as it is, with the mufflers?
Sounds very snarly with the straight pipes but I think the Gendarmerie would be unenthusiastic if I try this route....
nor all your Piety nor Wit
1977 GL1000 in bits
1978 SR 500 Yam
Your bike is "really great" looking machine. During a Cafe pic web search, your pic was one that was included. It really made me inspired to build one for myself. I just posted my first posting this morning on my '77 GW project. Thanks for the inspiration!
Devo26 wrote:
I was going to try to make some screens to put on them, but I read that the Por15 sealer can clog them up..
Any of the sealers will clog up screens and tubes. If you just use small amounts of POR15 and only add
enough to do the job, you'll be OK. Keep it moving until it sets and have the air hose handy (just in case).
Your bike looks awesome!
If we can't fix it, we can fix it so no one else can. the Condor BOTY 2011 Ol' Sparky BOTM Dec. 2011 Lucky #13 BOTY 2018
duke182 wrote:Just read through the thread again.
lots of great details.
Any chance you know the manufacturer and part number of the
Key switch yuo used?
The key switch is a barrel style key switch. If you do a google search you can find similar ones. I found mine at a local electronics store. I'm not sure who makes it. I had to run it to a relay to get it to work properly.
88hybrid wrote:What a sweet bike. I love the silver gl1000 plate around the custom fuel gauge. Was this made or did you buy it?
Thanks for the compliment. I made the plate. I used the original as a template and then glued some thin aluminum to a piece of particle board with 3M super77 and cut it out with my scroll saw. I then sanded it to the exact shape. Before I took it off the particle board I polished it. I then soaked the board and aluminum in acetone to separate them. I then designed the new logo and cut it out on my wife's vinyls cutter. I laid down my mask on the aluminum and then sandblasted the exposed areas to create the decal. It took a while but I really like the way it turned out.
Hal wrote:Beautiful job. This is the first time I've seen the thread.
Z50Lover wrote:Bike looks awesome! I might have missed this while reading through... how tall are your shocks?
Thanks!
I got the rear shocks from a friend. Not sure on the exact make or size. They are almost identical to the height of the stock shocks. They are quite a bit stiffer, which is why my friend was getting rid of them. I like them though.
Just found this thread - great work. Your pipes sound awesome! Great job on the polishing too. One of my favorite things about the bike - I woking right now on polishing the rear drive unit.
