MotoNudo Build
hmratbam
Re: MotoNudo Build
#76
Post by hmratbam »
Acquire a set of left hand drills. Much of the time when you are drilling for EZ-out or tap the brokenbolt screws out on the drill.
My Album
84 Standard ongoing project
Re: MotoNudo Build
#77
+1 on the left hand drills. Works over 70% of the time for me
Lads
Re: MotoNudo Build
#78
Post by Lads »
Got the front cover on and will check the seal when I do a bench test. Also finished the valve lap and installed the heads will new seals, etc.
Moving on to my next challenges:
84 clutch swap
Dyna S ignition
Starting with the clutch. Got all of the parts finally and starting the breakdown of the rear casing.
Removed the clutch cover, kept the clutch cable intact for now (I like to keep as much to together so I have fewer things to remember how to reassemble).
Removed the clutch plate, 6 bolts. Bent the tabs down on the washer and realized I missed one after trying to get the nut off (notice the 4 springs installed to get some friction while trying to loosen the nut.
Made my clutch tool, thanks various NGW members for the how-to. Used a 24mm socket.
Got the nut and washer out and then the snap ring.
Lads
Re: MotoNudo Build
#79
Post by Lads »
Just saw the post. Not sure why all the pictures repeated.
Lads
Re: MotoNudo Build
#80
Post by Lads »
Too many pics in the last post. Edited it. Here is the rest.
Time to remove the rear engine cover. Kept the kick starter intact. Needed to use a plastic scraper too gently wedge out the cover. Work evenly around the cover to keep the threaded studs on the lower right side and locating dowels from binding.
Once the cover was off, I removed the nut holding the scavenger pump sprocket and pulled the clutch basket, chain, and sprocket off at the same time. Removing one by itself will make the other bind up with the chain.
More tomorrow. Thanks to Sunbobb and Old Fogey for the previous posts found in ShopTalk. They really helped me out
Lads
Re: MotoNudo Build
#81
Post by Lads »
A lot of gasket cleaning and seal replacement later, I have a few updates;
Finished the head job, started the OF 84 clutch conversion
Checked the scavenge pump gasket and trimmed out the gasket with a ground-down exacto knife, it looked in good shape.
Learned how to load clutch plates in an 84 basket with a disk spring, fun times.
Rebuilt the slave and, after a false alarm, got it mounted on the clutch cover.
Built a rig out of scrap metal to bench test the engine. I know it may be wasted effort but I thought it would be fun and could make quick fixes on my engine.
Installed the required electrical and Dyna-S ignition. Will do a final check on the timing tomorrow.
Norbert R
Re: MotoNudo Build
#82
Post by Norbert R »
Cool idea !
What are your plans with the rad?, I see you have a long hose on the water outlet already...
Take a vid for us when you start it :orange
Nulla futuit datum...
1977 GL1000 - BOTM April 2015
Cafe Maximus Build Thread
Lads
Re: MotoNudo Build
#83
Post by Lads »
So I finished the Dyna install and static tuning. The octane thread and forum comments are a great help. I started working on the rats nest that was the wiring harness. The starter/run switch was gone, the starter disconnect switch was gone, and the headlight turn controls had been cut out. I made faster progress on the wiring and thought maybe.....
http://youtu.be/Hin7URAwkIM
After 25 years in a barn I was ready for a lot of trouble, turned out pretty good. Have some tuning to do but will wait on that until after the brake, wheel, frame work.
Thanks to all the NGW support.
Gowing
Re: MotoNudo Build
#84
Post by Gowing »
Just watched bench start, that's so cool. Be neat just to keep a motor in to demo.
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
Norbert R
Re: MotoNudo Build
#85
Post by Norbert R »
:bravo :bravo :bravo action1 action1
miltoncaniff
Re: MotoNudo Build
#86
Post by miltoncaniff »
Cool Vid! How difficult would it be to add a throttle and some way to produce a load to check it through the gears? Hydraulic pump?
I haven't put thought into it yet, would not want to over pressure the pump! (Danger, Danger Will Robinson!)
Maybe a gear/hydraulic driven propeller in water?
John
1977 GL1000/1976 GL1000
1975 GL1000/1975 GL1000 (Parts Bike)
2002 FLHRCI/1993 ZR750C3 Zephyr
1982 GS750EZ/1978 GS550
1978 KZ1000A2/1978 KZ1000A2 (frame only)
1980 KZ650F1/1979 KZ650B3
1979 KZ650C3/1981 KZ550A1
1977 KZ400A1 Deluxe/1979 KZ400B2
1982 KZ250D2/1980 KZ750E w/parts bike
This is not MY circus and You are not my monkeys!
Lads
Re: MotoNudo Build
#87
Post by Lads »
Not sure how hard that would be. Sounds pretty challenging.
I was just interested in making sure my work was legit and could be fixed easily. My next job would be to check dynamic timing and sync the carbs. I am not sure how effective that would be without the complete exhaust on it.
Lads
Re: MotoNudo Build
#88
Post by Lads »
Does anyone have a rear hub spacer that looks like this? My front spacer (already installed) had the flanges turned the other way.
Norbert R
Re: MotoNudo Build
#89
Post by Norbert R »
Yup, they do look different front to back. Mine were also a little chewed up so I straightened the little flanges before reinstalling
Lads
Re: MotoNudo Build
#90
Post by Lads »
Was cleaning the final drive and found this corrosion inside the final drive collar. The shaft looks fine so I am kind of confused. Any ideas on what to do with this?
