millerdog wrote:Starting plug gap is .028 to .030. Then you go down from there. They recommend the smallest gap possible, while still maintaining performance. I purchased some EMI shielding for the plug wires. Don’t know if that’ll help, but it can’t hurt I suppose. Gonna play around with the plug gaps too. I can’t believe I’m having this much trouble with this.Whiskerfish wrote:What does Paul recommend for the gap? I know with the dyna and the green coils I go to .035
C5 ignition
- millerdog
Re: C5 ignition
- millerdog
Re: C5 ignition
I’m gonna try that. Start with the widest gap recommended, and go down from there. I feel like I’m getting closer. It’s not nearly as bad as it was.CYBORG wrote:I run mine .30
Re: C5 ignition
I think the proximity of the plug wires may have been a big part of the problem. However the wires on mine were way to long and I just routed them around the engine to make them fit, and I have no problems. Just saying.
- millerdog
Re: C5 ignition
My thinking exactly. I’ve already cut my wires to fit unfortunately. May have to consider another set if I can’t sort this out. I’m hoping the shielding helps out.CYBORG wrote:I think the proximity of the plug wires may have been a big part of the problem. However the wires on mine were way to long and I just routed them around the engine to make them fit, and I have no problems. Just saying.
Explorer
Re: C5 ignition
You could always try shielding those low voltage wires if you think their close proximity to the plug wires might be the problem, most likely some aluminum foil under some electrical tape wrapped around them would work.millerdog wrote:Latest update. I rerouted some wires. Noticed I had some module wires a little close to the plug wires. Cranked it up a minute ago, and it will rev past 6 grand easily sitting still. Raining now, so I can’t take it out. I have high hopes. LOL. I’m hoping ignition was being scattered because of energy off the plug wires. Man, I’m excited. Stupid rain. LOL
We do it all the time at work to stop close proximity high voltage wires influencing low voltage control wiring.
- millerdog
Re: C5 ignition
I’ve got 12 ft of shielding on the way. I’m wrapping everything! LOLOLExplorer wrote:You could always try shielding those low voltage wires if you think their close proximity to the plug wires might be the problem, most likely some aluminum foil under some electrical tape wrapped around them would work.millerdog wrote:Latest update. I rerouted some wires. Noticed I had some module wires a little close to the plug wires. Cranked it up a minute ago, and it will rev past 6 grand easily sitting still. Raining now, so I can’t take it out. I have high hopes. LOL. I’m hoping ignition was being scattered because of energy off the plug wires. Man, I’m excited. Stupid rain. LOL
- millerdog
Re: C5 ignition
The latest. Got my shielding in, and shielded all the ignition wires except for the plug wires. Same thing. No go after 6 grand. I’m going to send the unit back to be tested. If it tests good, I guess that’s it for me with the C5. Back to a Dyna. I’ve done everything humanly possible for a plug and play. I’m not about to start messing with jets.
