CROSS OVER PARTS LIST
Ken L.
Re: CROSS OVER PARTS LIST
#76
Post by Ken L. »
Is there a cross over number for valve seals for the 75 GL 1000 ???
Thanks
Ken L.
2005 GL1800 Dark Grey Metallic, \ CSC Trike
1975 GL1000 Red (Owned since 1980)(Given to my other son)
1976 GL1000 Red (being restored)(Given to the Jones boys)
1978 GL1000 Black, dressed (Given to my son)
1985 Aspencade bought brand new, traded and now back home.
Ham Radio W8BUY
Old Fogey
#77
Post by Old Fogey »
The OEM number is a cross-over number already! 12209-300-003 is actually a CB750 number.
There are any number(sorry!) of dealers selling after market parts which are probably as good if not better than the oEM ones, especially if you find the ones made of Viton.
Ken L.
#78
Post by Ken L. »
Old Fogey wrote:The OEM number is a cross-over number already! 12209-300-003 is actually a CB750 number.
Thanks, I was hoping there was an automotive cross over that I could pick up at the local auto parts.
Ken L.
Ham Radio W8BUY
Old Fogey
#79
Post by Old Fogey »
Ken L.
Sorry, I can't help you with that. But here's the dimensions if that helps
unloaded measurements=stem i.d.x guide o.d. x tot. height x chimney height
12209-300-003 HONDA VS-454 .233 x .398 x .353 x .232
supplier; http://www.speedsupplies.com/accessoryl ... item=36380
http://www.partsnmore.com/parts/honda/c ... ry]=engine
Jdept
My Album: http://www.ngwclub.com/gallery/v/wingmans/jdept/
#80
Post by Jdept »
I don't know if anyone posted this part number but I just got a Napa auto parts Gold fuel filter for my ~3/16 or 4/16 fuel hose the filter p/n that's the right fit is 3001. anim-cheers1
~Jdept
1982 GL1100I *INW* :(
-naked, changed rear fender, different headlight, leather bags, rebuilt rear brakes and m/c, replaced front m/c with all metal type, removing as much rust as possible, polishing covers, and paint high gloss black...... to be continued. .....
~Looks to be a slow work in progress, a little bit at time is alright.
NGW Gallery --> http://www.ngwclub.com/gallery/v/wingmans/jdept/
Rubber Gaskets for saddle bags and such
#81
Here is where to find weatherstripping, rubber gaskets for saddlebags and such...
http://www.metrommp.com/
landisr
#82
Post by landisr »
To replace the black plastic decorative plugs over the handlebar mounting bolts for at least the 75-77 Wings and other bikes, look for them for an '86 Kawasaki Concourse. They aren't cheap, but they're available.
Ron in MI
metricinch
Zinc Member
Zinc Member
#83
Post by metricinch »
not sure if this is the place for it but according to my research the float valve for the GL1100 is Honda part 16155-168-681. fitment is for 83-87 Prelude.
#84
Wow, good find. I found those online for $14 to $20 each. That's a lot less than the ones for Wings.
Are you certain that they fit and work?
metricinch
Zinc Member
Zinc Member
#85
i will know for sure and for certain tomorrow as that is when mine will arrive at my local Honda car dealer. but in looking at the valve float set it is the same part number. i also found the float valve ref'ed on a few gl parts fiches...
#86
Very cool. See if you can post a comparo pic.
metricinch
Zinc Member
Zinc Member
#87
well that was a bust. turns out it was a secondary float valve. the hunt continues!
#88
I just added another part number for cam seals to Roady's post #2 in this thread. It is a Fel-Pro #TCS 45718. This sets contains two seals.
dposer
#89
Post by dposer »
ok i just found the correct numbers and such at autozone the rad caps new number is 7013 and the new thermostats number is 7240-160, thats a failsafe btw (also a 160 instead of 180). The thermostat is for a 1975 honda civic 1.5l, just in case they change the stupid number again i still couldnt find the fan switch (every one of the numbers and cars listed in this thread isnt available or the wrong one). The closest i found was for a 1980 honda civic 1.5l but its a m16 instead of 18, hopefully i can find an adapter for it. Well i hope that helps someone.
1978 gl1000
1982 cb900c
most of a cb900f
1987 toyota mr2
1988 toyota mr2 <--320k still runs strong
Rdltmc3
#90
Post by Rdltmc3 »
Gas cap for GL1100 (may also fit GL1000)
Stant 10810 ('81 Honda Accord)
this does not fit a gl1000 (at least my 78)
1978 gl1000 for sale to fund new project
