Fan thermo switch; is this right? (cheap FIX?)
Re: Fan thermo switch; is this right? (cheap FIX?)
#76
far better it be stuck on, then not turn on. However, I sure don't like the current draw
#77
rcmatt007 wrote:far better it be stuck on, then not turn on. However, I sure don't like the current draw
That's part of the reason I convert mine to front mounted modern fans. Better air flow, and lower current draw
tlbranth
#78
Post by tlbranth »
Got the Beck/Arnley, Part# 2011614 switch. Look around on ebay for a good price with free shipping. Got the connector here: http://www.cycleterminal.com/mt-series-090.html. The connector works great. I ordered 2 of them to get past the $5 minimum. Shipping was cheap. Got 2 connectors, shipped for under $10. Connector is completely sealed and latches onto the sender. There's a left and right hand version based on where the locating thingy is on the switch. I ordered MT090-R and I don't know why this would change for the 2011614 but as my wallet is getting down to the proverbial 'stems and seeds', I ordered the switch first and compared before ordering the connector. I've seen the connector on Amazon for a $12 or so apiece. So if you're flush.......
Here's a pic of the switch installed with the connector on it. I also drew up a schematic for wiring in a Bosch/Tyco relay. You NEED the relay. In the wiring diagram, black lines denote existing wires and orange lines are new wires you'll add. Dots are splices. The black wire between the fan and switch must be cut as shown. I've noted the wire gauges I'm using. The wires to the fan should be at least 18 gauge. The wires to the relay coil (85 & 86) can be 22 or larger.
Oh, one other thing I reckon you ought to do: lube the o-ring with something (I used Sil-Glide). When you tighten this puppy, the o-ring has to slide against something and it has the potential of getting a bit roughed up if not slippery.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
tlbranth
#79
Post by tlbranth »
Some added information on the Beck/Arnley switch. I tested it on the bench and it closed at 222 degF and reopened at 194 degF.
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
5speed
#80
Post by 5speed »
I replaced my factory switch with one similar but didn't wire in a relay..
When I attempted to test it by letting the bike idle the fan never came on..but the bike temp gauge never got anywhere close to running hot..
Should I add a relay do you think..just to be safe?
desertrefugee
#81
Post by desertrefugee »
5speed wrote:I replaced my factory switch with one similar but didn't wire in a relay..
Depends on what the switch is rated for. Some are 5A and some are 30A (with everything in between). I don't know what the factory switch is rated at, but Honda apparently didn't think a relay was necessary. Just another potential component failure in the fan's path, I'd think.
tlbranth
#82
Post by tlbranth »
Nobody seems to want to fork over power specs for this switch. I'm going by Roady's experience and the fact that the pins are pretty miniscule. A relay can't hurt and if the switch is rated at less than 4 amps it'll definitely help. Relays are incredibly reliable. My GL1500 has hundreds of them and nary a failure in 140,000 miles. The splices you make could be a weakness, so do them well. But I wouldn't sweat the relay.
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
5speed
#83
Post by 5speed »
tks. I will add it to the list. :)
Rednaxs60
#84
Post by Rednaxs60 »
Found this schematic for a rad fan relay and manual switch (optional):
Cheers
Ernest
1985 GL1200 Limited Edition
2014 Can-Am Spyder RT LE
2008 GL1800 (sold)
Sidecar Bob
#85
Post by Sidecar Bob »
ericheath wrote:I think it's in the shoptalk under crossover parts. I'll look and add if I find it. Here : FAN SWITCH
roady did the research for this, i didnt see it here in this list so here is the link to his post. octane posted the interchange list and it will fit a bunch of gl's.
http://www.ngwclub.com/forum/viewtopic. ... 3965#63965
here is the link to rock auto
http://www.rockauto.com/catalog/raframecatalog.php
click on part number search
here is the part number
2011614
The forum link doesn't work. I think I found the same information here http://goldwingdocs.com/forum/viewtopic ... 58#p231542
Beck Arnley Rad Fan Switch 201-0817
AIRTEX / WELLS Ref info: Cooling Fan Switch PN: 1S4485
Beck/Arnley Rad Fan Switch 201-1614
Duralast SW1888
Duralast SW648
ECHLIN : FS154
AC DELCO : A1854
STANDARD : TS306
4 SEASONS : 36567
WELLS : SW1888
NAPA (Echlin) FS131 or FS131SB
NAPA (Echlin) TS6045 or TS6045SB
I found that if I entered any of the NAPA numbers given into the search at napacanada.com it could not find any of them except for TS6045 but something is incorrect because it says that the thread size is 16mm. If I enter the original Honda number 37760-MB9-000 it finds NAPA # UNI FS131 but it says the thread size is 16mm as well. Either they have the thread sizes wrong or these are not the correct parts.
tlbranth
#86
Post by tlbranth »
Bobby - go up 7 or so posts. The switch I used works. I bench tested it and my findings are there. I also got a connector for it. Recommend a relay though.
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Sidecar Bob
#87
My "new" engine didn't come with a fan switch. I didn't worry about that at the time because I "knew" I had a spare good used one around here somewhere. But I can't find it so I'm trying to decide whether to use the one that's in my current engine or get a new one for the new engine.
The cheapest Beck/Arnley I can find would cost me over $47 CAD including shipping & border fees. PLUS the bother of wiring up a relay.
If the NAPA FS131 actually has the correct thread it would be a direct replacement (no relay) and I can pick that up locally for under $25 (tax incl.)
I just tried searching for M18 fan switch on eBay and found this https://www.ebay.ca/itm/311895681617 The listing lists a lot of bike models that it fits. For only $10.06 CAD it might be worth getting one and wiring in a relay.... And a "parade" switch too (just in case)....
I also have one of the ones the CX500 guys epoxy to the rad when they convert to electric fans that I could use too. But if I used that I'd need to find something to block the hole in the thermostat cover so that's starting to sound even more like work.
Sidecar Bob
#88
So I walked out to the shop and looked where I thought the good used one should be again and there it was :oops:
But that really cheap one on eBay intrigued me so I made an offer, the seller counter offered, I applied my eBay points and paid $4.06 (shipping incl.). I'll post back about it when it arrives.
Sidecar Bob
#89
My eBay bargain Suzuki fan switch seems to work OK but it comes on early and usually stays on. I realized why when I looked at the listing again: It is an 85 degree switch and the original is a 95 degree. It doesn't seem to be doing any harm (the voltmeter reads 14.5 with the fan running) so I think I'll leave it in until I drain the coolant to change it.
Don R
#90
Post by Don R »
tlbranth wrote:Anyone tried this'n?
https://www.ebay.com/itm/Thermo-Radiato ... .l4275.c10
That's the one I used, the beck arnley didn't thread into my 79 block.
