Same here I use a ratchet for that and make sure to only rotate it the way the engine normally turns. That means lifting up on the Ratchet to turn the engine.kitbutterfield wrote:If you're talking about the offset wrench for the generator bolt, I don't know that you absolutely need it.
I didn't have one, when I changed my GL1000 belts.
I think I used a 12mm socket/ratchet.
You also won't have the kick starter to contend with.
The NGW Project Bike. Timing belts. Removal/installation
DutchPurrpl
I'm glad to see that. That was one of my questions as I finish up the Front Engine Renewal procedures (most of them, at least). Strikes me that the ratchet would be a little extra insurance against racking the engine counterclockwise. I'm also fixing to put a masking tape arrow on the housing showing clockwise direction of rotation for when I'm really stupid. Wish me luck.kitbutterfield wrote:If you're talking about the offset wrench for the generator bolt, I don't know that you absolutely need it.
Dutch
DutchPurrpl
I don't recall seeing a specific torque for that. When that happens I find the same size of bolt that does have a torque value listed and if the thread pitch is the same and it is going into the same type of material I use that.
cgbarrett77
When using a 12 mm wratchet wrench, do I just put the kick stand in and pull it down out of the way and tie wrap it there so it isn't in the way? Does this effect the timing in any way? I am working on it first thing this morning so I hope someone can get back with me soon. By the way, thanks for all the great tips this far everyone. I don't know how I would do this without all of your help.
76 GL 1000
Another beautiful day.
- kitbutterfield
I'll assume that you mean the kick start lever...do I just put the kick stand in and pull it down out of the way and tie wrap it there
From what I recall, that may be necessary.
I believe there may even be a photo of that, somewhere on this site.
Pulling down on the lever will move your engine.
You'll then need to rotate it to the T1 position, to get everything set up.
KB
1976 GL1000 Nudewing
cgbarrett77
- kitbutterfield
cgbarrett77
done and done. I think I did it, and it starts and runs, yeah for me, lol. I am prettysure everything is in good order. Now I need to put the covers and radiator back on. Is there anything I should listen or look for when I take her for a ride later? I am sure everything is fine, but then again I did it so you never know wha I could have messed up, lol.
76 GL 1000
cgbarrett77
A few lessons for simple minded folk, like myself.
Lesson 1:
If you go to start your bike back up after chageing the timing belts and for some odd reason it won't start, maybe you forgot to hook the spark plugs back up,
Lesson 2: Once you hook the spark plugs back up and start the bike, if you notice an obscene amount of oil begin to collect around the left side of the bike, maybe you forgot to replace the timing mark cap,
I hope someone finds these tips helpful.
Lesson 1:
76 GL 1000
DutchPurrpl
Original Question: "Oh, I forgot...anyone got the torque specs for the thermostat housing bolts? GL1100, but that probably doesn't matter. thanks."
September 5, 2009; I did indeed have to tighten them...twice. Seems as things warmed up, there were some seeps...Not leaks really, just a few drops when parked after riding. All seems buttoned up fine now. But, oops, I just tightened them pretty darned tight, didn't get torque numbers.
Dutch.
Thanks, WF. Before I wrote the last post looked through the Clymer and tried using 7-10 ft./lbs (actually 7) per the cylinder head torque spec for 6mm bolts. I just felt like the thermo housing bolts were on the verge of breaking or stripping, and I stopped before the wrench clicked, figuring I could always tighten them.Whiskerfish wrote:I don't recall seeing a specific torque for that. When that happens I find the same size of bolt that does have a torque value listed and if the thread pitch is the same and it is going into the same type of material I use that.
Dutch.
- gw1982
- Zinc Member
Timing Belts
Hello Octane,
This is awsome, one cannot find such detail in a manual. I am going to do as suggested do the belt thing,old girl, no doubt has miles on. The guy i bought the bike from,,,was some sort of mechanic I think,but I am not taking chances. super job,god bless. Thanks for the welcome.
GL1100I GOLDWING INTERSTATE..1982
GL1100 GOLDWING (PARTS BIKE WAS IN A FIRE,NO PAPER WORK)
[img]http://i845.photobucket.com/albums/ab11/daddyt_photos/8475c69b.jpg[/img]
http://s845.photobucket.com/albums/ab11/daddyt_photos/MY%20BIKE%20GL1100I%20GW%20INTERSTATE/
DutchPurrpl
Re: Timing Belts
Good for you. I just finished with a lot of money saved and a feeling of security and satisfaction. If you're going into her guts, check this out as well:gw1982 wrote:Hello Octane,
http://www.ngwclub.com/forum/viewtopic.php?t=13108
Best!
Dutch
cgbarrett77
