Spin them suckers around
Greg
Re: Spin them suckers around
#91
Post by Greg »
Why doncha fired her up now so you can tell us all about it at the Meet. The story will be better in person than anything you can put in writting.....
:pepsi :popcorn:
#92
Post by HOTT »
What a great look. Who needs Webers. action1
Fire it UP!!
Kriss
#93
Post by Kriss »
anim-cheers1 Just picked up on this thread WOW :popcorn: :pepsi :drool FANTASTIC.
5x GL1000S, 2x GL1500,
gregforesi
#94
Post by gregforesi »
I almost pulled the trigger today. I got the engine all wired and plumbed in the test stand but didn't put water in it. I needed to think about it a little bit more.
HOTT - the Webers are just so tuneable. Not easy to get to know, but I've been living with a pair for 3 years now. The DCOE's are widely regarded to be the best running Webers. I think the way I have White Trash jetted would transfer over nicely to the DCOE's.
Robin thinks that re-jetting the stock CV's is doable. I'm a skeptic (not even my pin chuck will hold the small drills required to ream out those little idle jets). I'm going down to Indiana tomorrow and I have a hunch that this project will be discussed. Ad Naseum.
2006 GL1800 (Brutus Maximus)
#95
I would bypass the fuel pump for your start up. Just run line from test tank to the carbs. Just eliminates one thing that you don't know for certain works. It also allows filling of the carbs before cranking it over. If you do use the fuel pump pre-fill the carbs first.
gregforesi
#96
I've run the engine and everything worked as it should. The fuel runs are a lot longer now and the volume of the lines + front carb manifolds is probably 4 or 5 times what the stock system is.
I'll gravity feed the system and try to get all the air out before I crank it over.
#97
gregforesi wrote:snip.........
Shouldn't need to worry about any air. Unless you plugged something you shouldn't have.
Oldewing
Secretary
Secretary
#98
Post by Oldewing »
Great stuff. anim-cheers1
gregforesi
#99
OK. The bottom line is - it ran, and it ran pretty well.
The frst attempt showed me that I'm a moron. For all of you who were guessing the moron part - that video would have proved it. I was embaresd. I won't post it.
(I had the coils wired to the wrong sides.)
I fixed the wiring and it fired right up. Ran poorly since everything was way out of adjustment.
After a couple of attempts at adjusting the idle mix and the sync, things were much better.
The chokes are at about 3/4 closed. This is a really nice engine and I certainly didn't want to hurt it by running way lean.
(Robin - I didn't shim the needles for this test.)
I'm very pleased. These aren't Webers. There is no "growl" from the intake and that was disapointing.
You will hear a vicious intake leak from #3. I didn't put any lock nuts on the manifold bolts and the ones on #3 came loose. That's been fixed.
Dangeruss was right on the mark about it being flat off idle. It was flat everywhere.
I am confident that jetting and final tuning can be done with this design, but I'll opt for the DCOE's.
Dangeruss
#100
Post by Dangeruss »
Beautiful! anim-cheers1 The banner was a nice touch. :lol:
Russ
2016 K1600GT
75 GL1000 Project
States visited by Goldwing...
gregforesi
#101
It's football season.
Too bad my local team is the Lions.
KYpondman
#102
Post by KYpondman »
Fantastic, Greg! That was a quick concept to built and running!
Claude
Greg
#103
Post by Greg »
Not too shabby, eh? Good job.
#104
"I am confident that jetting and final tuning can be done with this design, but I'll opt for the DCOE's."
Dude, don't give up so quick. Send them down to me. ;)
They won't "growl" so much until you get the jetting right. What you need to do first is to just let it idle for about a minute. Then shut it off and pull all 4 plugs. That will give you an idea where the pilot jet's are.
Then you can play with the washer's we talked about. Mic them to be sure they are all at least real close to the same thickness. You may need more that one. Or thicker one's would be better if you can get them.
Dangeruss
#105
Post by Dangeruss »
Oh Boy, I would be temped to put a set of Keihin CR Specials on, very tunable direct lift round slides.
You'll find the power you need to win with Keihin Round slide Special CR side draft Carburetors. The choice of Team Honda For years on all of their in-line 4-cylinder race bikes in Super bike, World Championship Endurance and Formula One classes, Round slide CR Carburetors continue to win. 10% Horsepower Gain: Smooth venturi design produces stronger power than original equipment carburetors using butterfly throttle valves. Improved Throttle Response: Direct throttle linkage to slides provides more precise control than vacuum slide carburetors. . Keihin Round slide Special CR Side draft Carburetors are designed for use on side draft 4-stroke motorcycle engines. Intake length is adjustable for better tuning. Sizes available are 26, 29, 31, 33, 35, 37, and 39mm.
I have a set on the 900F and did they ever wake up that motor without a big fuel mileage penalty. There is no accelerator pump, so you have to roll on the throttle instead of just stabbing it, but you better be hanging on when you get on the cam. Probably not any cheaper than the Webers though. Oh, and they do growl very nicely. devil1
Besides, if you do all the foot work, I won't have to later . . . . lolol
Russ
2016 K1600GT
75 GL1000 Project
