Dark GreenWing 1977
codyjames707
Re: Dark GreenWing 1977
#91
Post by codyjames707 »
Christmas came early! Or, ugh, late?? I'm going to go with early, because look at this! I posted a little but ago needing an extra carb system and this gentleman named Al from Iowa responded with a pair from a '76. I was stoked to see the carbs he had, and offered to pay for them and shipping. But Al began cleaning them and putting them through his ultrasonic cleaner, then he kept going further. He went so far as to polishmost of the parts and even rebuilt the carbs with a randakks carb kit that I sent over. C'mon! Al is going above and beyond here!
Al basically went 1000 [slight pun intended] percent above and beyond what I ever asked for, he didn't have to do a single thing besides mail it over, but he did way more. I can't thank him enough for his time and generosity. Thank you Al! The carbs are looking oh-so-clean! (bottona is his name on the forum) anim-cheers1
1977 Gl1000 DARKGREEN-WING
BOTM April, 2018
viewtopic.php?f=16&t=59710
Sugs
#92
Post by Sugs »
Nice deal there!
_______________________
'79 Honda GL1000 Goldwing
Easter
#93
Post by Easter »
That is wonderful, lucky you.
83 GL in process :IDTS:
#94
Good job, Al
codyjames707
#95
So I have been wondering if anyone else has done this. The pressure gauge on my front forks has stopped working (which I dont really care for anyways). And I was thinking about just replacing those big bulky things anyways. HAs anyone in here done so with success? I know the fork tubes are 37 mm, would that make the caps the same size when looking for them?
I found this pair for $30, and if it can clean up the front end, I figure, why not?
BOTM April, 2018
#96
Thread pitch needs to be the same too. But yes, that would work. Unless you have the stock springs. If you have Progressive springs they should fine without the air.
kermit
#97
Post by kermit »
Hi Cody
When you find the part number of some caps please let us know as I am looking for them right now.
Thanks
1988 Goldwing Aspencade (now sold to a good home)
1984 Goldwing Interstate (presently very pissed at me due to new child)
1978 Goldwing modified Cafe Racer (first out for 2017 and now dirty)
1979 Gl1000 Nasty Child Build
1980 Gl1100 running around naked (presently looking at me with a disapproving look)
codyjames707
#98
codyjames707 wrote:It is time for me to start thinking about headlights, and I was wondering about some of your inputs on what would work..
I'm not trying to spend too heavy on a headlight set, but these seemed to be in a nice simple middle ground. Wondering which ones you guys think would work best, or if you guys have any personal experience with these change outs.
https://www.amazon.com/Speed-Headlight- ... motorcycle
Both seem good to me, but I am curious for some input!
I ended up ordering the second option that is the image above. The casing turns out is metal, gloss black and headlight all together felt solid. Honestly, if any one is looking for an aftermarket headlight, this one was a solid replacement!
BOTM April, 2018
#99
robin1731 wrote:Thread pitch needs to be the same too. But yes, that would work. Unless you have the stock springs. If you have Progressive springs they should fine without the air.
I thought the 1000's had airless forks to begin with?
#100
they did from the factory, but there where aftermarket kits to convert them. If I had a problem with the stock springs, I would install progressive replacement springs. In fact I did on my 78
#101
CYBORG wrote:they did from the factory, but there where aftermarket kits to convert them. If I had a problem with the stock springs, I would install progressive replacement springs. In fact I did on my 78
Yeah, and OP talks about it having air. That means they could have used different springs when they put the air on. And they could still be the original 40 year old springs. So due for new ones anyway. ;)
codyjames707
#102
Hey everyone! I wanted to share some quick information. I've been looking at new speedometers and tachometers to replace the bulky stock ones and was confused when it came to the ratios. Seeing a bunch of different answers with a lot of uncertainty, I finally found a solid website with clear information. So just incase anyone was ever wondering and needed answers like I did 3 hrs ago, here ya go!
Speedometer: 60mph : 2240rpm
Tachometer: 4:1
The website is: http://mostynindustries.com.au/speedo-tacho-ratios
BOTM April, 2018
BikeMaine
#103
Post by BikeMaine »
codyjames707 wrote:Hey everyone! I wanted to share some quick information. I've been looking at new speedometers and tachometers to replace the bulky stock ones and was confused when it came to the ratios. Seeing a bunch of different answers with a lot of uncertainty, I finally found a solid website with clear information. So just incase anyone was ever wondering and needed answers like I did 3 hrs ago, here ya go!
Tachometer: 4:1
I needed that, thank you Cody
Kevin
1982 GL1100A
codyjames707
#104
So I was putting the brakes on the bike when I realized
1) I'm having a fitment issue.
And 2) I have two right brake calipers, but one seems MUCH larger.
Can anyone tell me which one the larger one goes onto?
BOTM April, 2018
codyjames707
#105
Since not so many people helped me with my last question, figured I'd just give an update if anyone falls to the same problem.
The larger brake caliper mount was for the forks of a 1975-1977 gl 1000. The smaller mounts go for the 1978-1979 models.
Even though my bike is mainly a 77, the forks are from a 1978 model and thus where my confusion came from. I found a caliper and mount on ebay for $40 and boom! The problem was fixed and my front brakes are working great!
dancr
BOTM April, 2018
