CROSS OVER PARTS LIST
Re: CROSS OVER PARTS LIST
#91
A poor fit on my 1100 as well.
#92
Removed from the list. :oops:
Marc
#93
Post by Marc »
I don't know if anyone posted this part number but I just got a Napa auto parts Gold fuel filter for my ~3/16 or 4/16 fuel hose the filter p/n that's the right fit is 3001. Jdept
I think he meant Napa Gold Part Number 3011. 3001 is much too big, 3011 has a 1.4" diameter, just a little bigger than our stock 1.25" OEM filter but will fit if you use a little bigger screw in the filter bracket and bend the tab that the screw goes in very slightly.
Couldn't find a cross reference for an air filter??? Anyone know of one?
Shalom, Marc
1975 GL1000 "Dresser"
1976 GL1000 Project Bike
1979 GL1000 Naked
2007 Triumph Bonneville
1970 Norton Commando
#94
BikeBandit has aftermarket filters. They fit right nice. :-)
Marc
#95
Post by Marc »
The price is right too: $11.01 with free shipping. I'm just not to comfortable with the EMGO brand. Might give them a try, if the fit is good there is not much to go wrong with an air filter.
Shalom, Marc
1979 GL1000 Naked
britman
#96
Post by britman »
Ive been looking for an 83 speedo cable couldn't find one for an 83 . But a GL1500 speedo will fit has the same end as the 83
1983 gl1100 fully dressed the best colour black -- 1982 gl1100 going naked and black too 1983 Yamaha virago 700 also in black
trevor42
#97
Post by trevor42 »
Spark plug boots:
NAPA part #: NGW8072
"No battle plan survives contact with the enemy." - Prussian field marshall Helmuth Karl Bernhard Graf von Moltke
1979 GL1000 - rebuild in (slow) progress
#98
Thanks, I've added it to the list.
(Part # seems appropriate, NGW=NakedGoldWing :-))
Scottinaz
#99
Post by Scottinaz »
according to Napa, there has been a supercession on the radiator cap part number. New number is 703-1697
'76 GL1000
#100
List has been updated.
taylorsel
#101
Post by taylorsel »
Radiator hose
I went into auto zone and gave the part number in the first post- AutoZone - #B70834 ($9.95) does both top & bottom and got the deer in the headlight look
They let me look and I found a hose that fit better than the last few i got.
B71382 cost about $10 and I got both the top and bottom out of one hose
STEVE LOGAN, 1979 GOLDWING, 1978 GOLDWING, 1976 GOLDWING
Marc
#102
Post by Marc »
Thanks, I will try that.
Shalom, Marc
1979 GL1000 Naked
Danny-boy
Rusty Probie
Rusty Probie
#103
Post by Danny-boy »
Is there a part number for a 83 gl1100 temperature sending unit. Maybe Napa or Auto zone?
d9canada
Brass Member
Brass Member
Re: Motor swap
#104
Post by d9canada »
Sidecar Bob wrote:
stkelly2 wrote:Any body know if I can replace my 1000 with an 1100? I know the motor will bolt right in but what other issues Might I run into?
If you run an 1100 transmission and a 1000 final drive the gearing will be way too low.
I have the opposite - a 1000 engine/transmission and an 1100 final drive and the overall gearing is more than a gear higher - the mileage is a lot better and I don't find myself looking for 6th gear nearly as often.
I understand this is an old thread but I have a question that hopefully someone can answer. Regarding the above quoted post - am I right in assuming that the key information is that the 1100 final has 'faster' overall gearing (numerically lower reduction) than the 1000? And will the 1100 final bolt up to a 75 GL1000?
Also regarding parts interchange, does anyone know if the 75 GL1000 grab bar is the same as any other Honda model/year?
And one more query, see my recently purchased GL in my profile pic - the seat bolts up to the original mounts so I assume the seat pan is OEM. The pan is in great shape, no rust or obvious alterations. Does anyone know if the seat foam/cover is a Honda spec or does it look like a Saddlemen kit or similar? I'm sure it's more comfy than the old breadloaf but I'm just curious.
Barnzie
82 CBX Prolink
75 Goldwing GL1000
81 Silverwing GL500 & 82 Interstate
83 CX650E (Euro version)
Honda 4s 350F-900C
Motorvation Formula II sidecar on CB900C
Sandcast CB750 1003245
63 Honda C105T 55cc Trail
83 Honda 750 Shadow
73 Norton 850 Commando
79 Yamaha XS1100SF
02 Sportster 883
:crosso
taylorsel
#105
Post by taylorsel »
On your seat It is an aftermarket seat not OEM. It might be a saddleman. dont know. Some of those seats used original seat pans. I had one. I just modified the foam to fit a original type seat cover. Original seats are a little hard to come by. Look to spend $150 to $200. And you'r right, origanals are not as comfy.
