What Did You Do To Your Wing Today?
Re: What Did You Do To Your Wing Today?
#9241
Was going top take the LTD for the state inspection. Would only get a burp from the horn (when I hot wire the horn it is fine. Spent yesterday going back through all the wiring.... nada.... still have the neutral light on full time. Checked the red wires at the battery and then nothing worked.... so I spent this afternoon re-wring the two red wires and put a new master fuse in line. Still nothing from the horn.
#9242
Maybe use the horn wires for the starter? Nope, they would melt pretty darn quick. Does she turn over when you jump the two big terminals on the starter solenoid?
Rednaxs60
#9243
Post by Rednaxs60 »
1200 crank seal and 1500 crank seal are the same.
Ernest
1985 GL1200 Limited Edition
2014 Can-Am Spyder RT LE
2008 GL1800 (sold)
#9244
Rednaxs60 wrote: Mon May 13, 2024 6:34 pm 1200 crank seal and 1500 crank seal are the same.
action1 action1 action1 action1 action1 action1
ritalz
#9245
Post by ritalz »
Doing some maintenance on the 1200 today. Brake light switch on the handlebars is a little touchy and sometimes the brake light stays on. Time will tell if I fixed it or not. Airing the tires presented another problem. The valve stem on the rear broke off at the rim. Gonna try to break the bead and replace the stem without removing the wheel. I've done it before and it is not easy but it is a bear to pull the wheel on this bike. It's worth a try. Hardest part is getting some free time to get it done.
Jonesz
#9246
Post by Jonesz »
Well at least the valve stem broke in a safe place "home". Could have been an accident if it separated at speed. A nuisance for sure but be thankful.
Jonesz
1979 Suzuki GS850. Sold
#9247
Jonesz wrote: Mon May 20, 2024 9:42 am Well at least the valve stem broke in a safe place "home". Could have been an accident if it separated at speed. A nuisance for sure but be thankful.
Morning dog walk through the neighborhood and see a neighbor's Chevy 1500 half in and half out of his drive laying on the A Frame with the tire all cocked up. He was just getting ready to jump on the thruway and realized he forgot something and went back to the house. Half way in the approach to his driveway the lower ball joint snapped. happening there very possibly saved his life and at a minimum saved a nasty wreck. Sometimes we get lucky!
ritalz
#9248
Post by ritalz »
Two safe places in a row, could have been lots worse. Years ago our kids took our car to six flags with friends. Upon leaving the park a ball joint snapped partially blocking an exit. A major inconvenience but again no one was hurt.
ritalz
#9249
Post by ritalz »
Popped the bead and replaced the stem with a 90 degree metal stem. Worked out pretty good as it only took about 2 hours including a short break out of the heat. It's already 86 out there this morning.
#9250
Straightening up some in the shop today and stumbled on the seat I bought last year at Vintage days. I took the gunfighter off the 75 and mounted this one up. I think I like it. It has a similar shape to the Corbin touring saddle but is softer. No idea who made it. Also I finally fixed the defective side cover spring latch. Been afraid of loosing that battery cover for years! Maybe tomorrow I can get out for a bit of a ride and test the seat.
Also the Crank shaft seals for the 1200 arrived today. Maybe tomorrow will see her on the surgery table if I get time.
#9251
200 miles into a second day with big trailer was about to pull in for fuel and heard a sound. Left rear wheel had loose lug nuts. Replaced in parking lot. Wheel is ruined
#9252
Near miss … seems to be a theme this week …
Good that you caught it … hearing can be useful … so I hear …
Gord confused22
#9253
Beth couldn't hear it. But as I used to tell residents it you do not know what you are hearing an amplified stethoscope is useless
#9254
Between putting loads into the truck for tomorrows run I snuck out on the 75 for about 120 miles. I like the new seat very much. Only thing I would like to improve on is that is sits just a bit too far back. I think if I remove the tongue and move the rear brackets to just the back set of studs I can move it forward about a inch. There is close to that much gap to the shelter. That would make a good deal of a difference. I would do it today but the tool box is loaded in the truck and strapped down.
#9255
Check the lug nuts
Return to “NGW Club House”
