What Did You Do To Your Wing Today?
Re: What Did You Do To Your Wing Today?
#9331
ritalz wrote: Sat Dec 28, 2024 9:50 pm Got in a short ride on the 1200 today. Bright and a sunny 55 at 10 am and downhill from there. Full overcast and 53 by time I got home. Enough to chill. First ride in over a month due to a medical issue.
Yeah to Al, great to see you mobile again. Hope the family is also improving.
#9332
Yep I got just over a 100 miles on the 84 as well. A little windy and cool but still good to be out
OhioBill
My Album: http://www.ngwclub.com/gallery/v/wingmans/OhioBill
#9333
Post by OhioBill »
I didn't get to ride even though it was 60 degrees, I had to make one last pass on the yard for leaves. But I have been reinstalling the stock exhaust on my 78. Like Whiskerfish referenced the ear speakers are a great addition for longer rides. Trying to quiet the bike down so I can really enjoy the tunes.
OhioBill
Retired and Loving it.
1979 Black (to be restored)
1979 Blue (Sold)
1993 blue 1500 Sold
1976 Restoring
#9334
Not the bikes but the shop got a new stereo today. Picked up a "new in box" low end Onkyo receiver off FB marketplace. Shop sounds really good, maybe that will provide some motivation to do some work out there!
#9335
went out to work on the M3W. of course there is about 1.5 qts of oil in the sump. Turned it over to pump that back into the external oil sump. Instead it puked a bunch out the intake manifold. So I pulled the plug on the so-called dry sump and drained it... then it was too cold to do anything else
pidjones
#9336
Post by pidjones »
Started cleaning the front wheel. Anything to avoid brake work, I guess. There are about five spokes with surface rust through the cad plating. Wondering if it is Ok to remove that rust with Scotchbrite? I've miced them and the spoke diameter doesn't drop more than .01 mm after cleaning.
theailer
#9337
Post by theailer »
Whiskerfish wrote: Tue Apr 02, 2024 6:54 pm I ran 2 tanks of Non Eth Gas through the 1800 today. Boy that really shook out the winter cobwebs!!
Crap, that reminds me that I've yet to add some fuel stabalizer to my bikes this winter...
#9338
rcmatt007 wrote: Tue Jan 07, 2025 8:54 am went out to work on the M3W. of course there is about 1.5 qts of oil in the sump. Turned it over to pump that back into the external oil sump. Instead it puked a bunch out the intake manifold. So I pulled the plug on the so-called dry sump and drained it... then it was too cold to do anything else
can't believe you don 't have heat in that shop :roll:
#9339
solar panels on the roof, but, yes no heat
#9340
rcmatt007 wrote: Tue Jan 07, 2025 8:46 pm solar panels on the roof, but, yes no heat
might want to think about it. global warning won't be in Va. for a while :lol:
#9341
climate change....
#9342
rcmatt007 wrote: Tue Jan 07, 2025 9:00 pm climate change....
ya... it's happened before :)
ritalz
#9343
Post by ritalz »
Spent a couple of days working on the seat from the 1800. I have an aftermarket Corbin with heat that needed some adjustment to fit me better. Peeled the cover back about half way to expose the foam. Trimmed the foam on both sides where my thighs contact the seat to help with being vertically challenged (5' 6"). That brings my legs in closer to the bike and gets my feet flat on the ground (I hope). Additionally I beefed up the foam a little to soften the contact points for my backside. The goal is to increase the time in saddle before feeling the need to stop just to get some feeling back and to comfortably reach the ground any time I had to stop. The Iron Butt ride in October convinced me that something had to change.
gregforesi
#9344
Post by gregforesi »
pidjones wrote: Tue Jan 07, 2025 2:07 pm ...There are about five spokes with surface rust through the cad plating. Wondering if it is Ok to remove that rust with Scotchbrite?
Maybe.
I had torn down the wheels for powder coat. I "polished" my stock spokes which had a bit of surface rust. I year later they were all covered in rust-rust. I had polished all the cadmium off leaving the steel unprotected.
Now they are stainless from an outfit in Great Britain.
That was a fairly expensive and highly annoying lesson.
2006 GL1800 (Brutus Maximus)
ritalz
#9345
Post by ritalz »
Worked on the rear shocks on the 1200 today. The air assist shocks were like riding on a log wagon. Found out there was almost no fluid in them. Hung them upside down and even pumped them and and next to nothing came out. Some cleaning and refilling made all the difference in the way it rides. They still seem to hold air so I didn't mess with that part other than making sure the lines sealed up. Also found a leak in the rear wheel that forced me to change the filler valve. I'm back in business.
Return to “NGW Club House”
