Lightswitch for spotlights
Annie's Boyfriend
Post by Annie's Boyfriend »
Ok. so now the fairing has gone and I am working on my frame and chrome, I have to somehow install a switch to get two spotlights to work along with my headlight.
Any thoughts on how to do this, my fan needs a switch too as it was operated from a switch mounted in the fairing. :oops: :oops: :oops:
All of your ideas are welcome. :-D :-D
Bart
Annie
Dreamboat Annie
Little Ship of Dreams ...........
( lyric from "Dreamboat Annie" by Heart)
[url]http://www.nakedgoldwings.com/gallery/Dreamboat-Annie[/url]
[img]http://www.hondagoldwings.com/images/cliparts/eagle3_small.gif[/img]
[img]http://www.nakedgoldwings.com/forum/images/flags/Netherlands.gif[/img]
Dougal
Post by Dougal »
To overcome this problem I fabricated a piece of aluminium plate of about 2mm in thickness, to fit over the rearmost handle bar clamp bolts. With a bit of care you can install up to 4 small switches.
An alternitive is to mount them inside the dummy tank, or in the dummy tank lid. Possiblly removing the Goldwing name plate and drilling into the lid there. When it comes to the time when you sell the bike, you can replace the goldwing name plate and the holes will be hidden.
BTW I always use a relay to switch additional electrical loads, using the switches to operate a relay. That way the extras can have there own feed from the battery, fused accordingly and the feed for the switches can be taken from the accessory fuse as there is only minimal current used to power the relays.
Dougal
They say WHY?, I say why not.
Annie's Boyfriend
Dougal wrote:To overcome this problem I fabricated a piece of aluminium plate of about 2mm in thickness, to fit over the rearmost handle bar clamp bolts. With a bit of care you can install up to 4 small switches.
Dougal
Do you have a picture of that ??
Thanks for answering so fast.
Bart
Annie
Dreamboat Annie
Zryder
Post by Zryder »
Hey A's B , you should connect this item up if you are going to use the spotlights with a light bar ,a smart switch its called . I don't have it yet but will be ordering . http://cw-intl.com/en/detail_products.asp?id=3312 :)
Annie's Boyfriend
Zryder wrote:Hey A's B , you should connect this item up if you are going to use the spotlights with a light bar ,a smart switch its called . I don't have it yet but will be ordering . http://cw-intl.com/en/detail_products.asp?id=3312 :)
Oh my god, they got a lot :oops: :oops:
Bart
Annie
Dreamboat Annie
Dougal
Post by Dougal »
Sory I havent and I took it off and scapped it about 5 or 6 years ago.
Just mes with some cardboard until you have a shape that looks good, then make it out of alloy.
Dougal
Annie's Boyfriend
Dougal wrote:Sory I havent and I took it off and scapped it about 5 or 6 years ago.
Dougal
I was wondering what you meant with "rearmost handlebarclamp" :oops: :oops: :oops:
Bart
Annie
Dreamboat Annie
Dougal
Post by Dougal »
Dougal
Bart
No its me who should be :oops: I missed a owrd out. It should have read reamost handlebar clamp BOLTS. I you look its suprising how mach room is there when a plate is bolted on using these bolts.
Dougal
Annie's Boyfriend
Found it
I think I will go for these:
They should fit between the handlebarclamps, I hope......
Bart
Annie
Dreamboat Annie
