Help!...Unique Engine Squeeling Noise
- soxfanscott
Hey gang, My 1978 GL1000 has developed a squeel as the engine was idling today.
Some background, I start the bike once a week during the winter. Back it out into the drive when weather permits. Today I was giving her her Sunday exercise. After about 5 minutes or so the engine started to squeel, a belt like sound.....
Not from the front of engine......the squeel increased with RPM etc, I shut her down quickly etc and wheeled her back in...
Any ideas?
Any ideas?
Dad, thanks for everything you have done.
1978 GL1000 Daily Ride 92k miles
- Zacsdaddy
Does it squeal only when you're moving?
If not, then is the squeal in time with the rpm's of the motor?
If it's when your moving only then it's the speedometer or cable.
If it's only with the rpm's of the motor (reving it but not moving) then it's the tachometer.
The cure for either (for me) was the same. Remove the cable from the offending gauge and shove, jam and slather grease onto the end of the cable. Put it back where it belongs and ride it for a while. If the noise continues, do it again. It took three applications on my speedometer and twice on my tach but they've been quiet ever since.
Zacsdaddy
Zacsdaddy
1981 GL1100 That Mama found and bought for me.
1975 KZ400D That I found for Her and brought back to life.
"If the Women don't find you handsome, they ought to at least find you handy" - Red Green
How cold was the outside air? What oil are you running? and weight??
I wonder if your starter clutch disengaged after it started? Sometimes after a cold start you will get a loud squeel as the starter clutch disengages. It is a pretty nasty noise.
- soxfanscott
Zacsdaddy:
Not riding the bike at any speed. Too much snow still around here, but it is disappearing fast. So that would eliminate the speedo.
Whiskerfish:
Ambient temp was about 40-45 Degrees. Am running 15-40 oil. Shell ROTELLA® T SAE 15W-40. The squeel started probably about 5 minutes after the cold start. Engine had come to full temp, radiator fan on etc.
Was coming more from rear of engine/ trans area. Gave it a bit of gas, squeel followed rpm increase. Hit the kill switch asap.
Whiskerfish:
- Cookie
- RIP: 1950-2011
Or hitting the starter button again and see what it does. If that does not make it change then if it is on the center stand I would drop it in gear and see what it does.
- soxfanscott
- soxfanscott
- dan filipi
- My Album: http://classicgoldwings.com/forum/galle ... album_id=1
- Cookie
- RIP: 1950-2011
- BerlinKowgirl
- Lady Winger
You should just let the bike alone and hibernate until the snow is gone and you can ride her. Not good for the engine to start it every week and not drive it.
Cheers,
Peewee
Cheers,
Peewee
Cheers! Peewee
1976 Honda GL1000 (put in shed, threw away key)
1978 Honda CX500 (the winter bike)
2001 Aprilia SL1000 (daily driver, my pride & joy)
And a bunch of projects not worth mentioning...
- todd54219
I agree with PeeWee. If you cannot put at least 15-20 miles on it, do not run it. The moisture in the exhaust will kill your exhaust system. The muffler does not get hot enough to evaporate the moisture and it will rust from the inside out.
Todd
Todd
1976 Yellow GL1000
1976 Yellow GL1000
bum
I agree with Cookie
It might be the speedo cable screaming in the cold. That's the main reason I moved from NYC to california....I too used to scream in the cold. 8)
bum
8 wings + 1 Triumph +2 Musclecars = 1 pissed off wife !!!
