Got the GW running today 82 Gl1100I Minor probs need advice
K111969
Lead Member
Lead Member
Post by K111969 »
Hello again everyone. I got the GW running today. Yippee... as I expected the previous owner wasnt COMPLETLY honest with me about the condition of the bike. hehe I need some info on carburation please the bowls are leaking more fuel than they are spraying. and there is a terrible clunking coming from what I can only think is the clutch basket it happens when i rev the engine hard only low in the rev range up higher its not bad. Ive never owned a wing before so I dont know that it isnt normal. sounds like hell though.
Sorry for the long post but Im a newbee so please dont blast Me. hehe
Thanks John K1
1982 GL1100I Black
"It is Not a Sin to Die Doing what you Love"
"I have come here to chew bubblegum and kick ass...and Im all out of bubblegum"
toad
Post by toad »
sounds to me like a fuel problem carbs out of balance!!! set up the carbs first before anything else!! ;)
gravity is a myth the earth just sucks
RebelRouser
Webmaster (Retired)
Webmaster (Retired)
Post by RebelRouser »
Hey K1;
As Toad Said Get Your Carb Problem Fixed And Out Of The Way First, You Might Be Leaking Excessive Fuel Into Your Engine As Well As Out The Bowls... So Deal With The Carbs First Then Figure Out The Rest... This Is One Of Our Fellow Members, http://www.randakks.com/
Hope This Helps....
(beter Queeenie....)
QUEEENlE
Post by QUEEENlE »
Rebel you got it backwards ...lol well the names anyways .... K111 has the carb issues ...Toad was helping ...too funny ... Grammer lessons and paying attention ....starts March 1
Hugs
Q
octane
Post by octane »
Hi K
WELCOME !!!
Could be due to a number of reasons,
but most likely one or more float needles are stuck open,
, damaged or just crap needles that cant keep tight.
(or they could be misssing( ! ). Seriously; I bought a
set of carbs of a "running" bike and two(!) of the needles
were simply missing...must have been "running" kind of funny).
The bad news is that in order to fix it you need to take of
the whole four-carb-thingie and dismantle, check and fix.
If you take that route, check these links:(note: these are all for the 1000GL models)
CARB REBUILD
and
CARB REBUILD 2
and of cause
Randakks
for the best carb page on the net.
and get a good workshop manual like Haynes, Clymer or the official Honda Workshop Manual.
Check this link: Manuals
and
Manuals
Good luck and please ask questions, so we can help you through this!
Octane
Da' Supercharged Bulldog
Antoine de Saint-Exupery
from all of thise discussion, I think it might be a good idea to actually look inside the ebay carbs I bought for my project
Float bowls leaking
On the leaky float bowls, could just be junk stuck in the needle seats.
Try tapping the bowl sharply with a screwdiver handle or somesuch.
If you get some improvement, run some Seafoam through her before you tear everything apart.
If it doesn't work, tear everything apart :cry: .
Gord :roll:
several years ago I had one carb that was not working well on my '78... I drained the carbs, ran a half and half mix of carb cleaner/gas (disconnected the fuel line and used the fuel pump to pump it in) into the sticking carb and let it sit. I know now to drain this after sitting, but then I just started it up... eventually the mixture burned out (lots of smoke) and the carb began working....
this trick is on Randakks site (but I did it in '85 before there was a net, so I am claiming credit for the idea...
if it works for your carb... great.... if not, what have you lost, but a little time
K111969
Lead Member
Lead Member
Post by K111969 »
Thanks for the advice everyone. I knew from reading previous posts Id come to the right place to find helpful people. Will post again this weekend when I get a chance to work on it.
Later All K1
1982 GL1100I Black
Bandanna
Post by Bandanna »
yeah k1....
sort the leak out sharpish..
wouldnt want to see your next posting with the words "fire in the plenum destroys goldwing"........
:shock:
