Triple Tree
DonS
Brass Member
Brass Member
Triple Tree
Post by DonS »
Does anyone have knowledge of a switch for the top portion of the triple tree on a 75-79?
I have a copped 78 and I need to change my handle bars to make the bike look proportional. I own a set of 1" bars but would need to mount them on risers or pull backs to clear the custom tank.
It looks like a simplified triple tree top like what comes on newer bikes would be the answer; has anyone changed the top of the triple tree out?
Any constructive suggestions will be appreciated, Don
DonS (inhiswind)
Smokin Mo
triple tree
Post by Smokin Mo »
Maybe if ya got some 7/8 dog bone risers and then cutout one end to 1" to fit yours bars. Also I found out ya can use harley triple trees. You just need to size the right size of bearings. The harley stem is smaller than the honda. I'd like to get some slightly raked ones after the holidays.
Smokin Mo
HD trees
Post by Smokin Mo »
I just got off the Cycle X web sight. They have bearing cups for converting cb750's over to HD trees. There have been post on this sight that there is speculation that 750 trees fit 75-77 gl's. If so the the bearing cups should work.
You have a link to that CycleX conversion page?
Smokin Mo
Triple trees
Post by Smokin Mo »
http://www.cyclexchange.net/Honda%20Page.htm I just received the beach bars 39". Now I'm ordering the oil filter/cooler adapter. I received an email from the guy they are now working on a high performance ignition for a GL
COOL NEWS! The wings are gonna make a rebirth...
snuffymanson
Brass Member
Brass Member
Re: Triple Tree
Post by snuffymanson »
I'm a member on a couple 750 chopper boards , and some of those guys have found that the first 2 years GW trees will swap straight over . ( they like to run the wider front ends )
Kenny
you call it fabrication ? I call it blacksmithing .
1981 G L 1100 minor mods
1976 C B 750 chopper
KYpondman
Re: Triple Tree
Post by KYpondman »
Hey Sunnbobb, that's an interesting site.
Thanks,
Claude
DonS
Brass Member
Brass Member
Re: HD trees
Post by DonS »
Smokin Mo wrote:I just got off the Cycle X web sight. They have bearing cups for converting cb750's over to HD trees. There have been post on this sight that there is speculation that 750 trees fit 75-77 gl's. If so the the bearing cups should work.
DonS (inhiswind)
Scott Ironhorse
Brass Member
Brass Member
Re: Triple Tree
Post by Scott Ironhorse »
What years do the top triple trees cross over? They look the same for the first several years. If a company.. say cyclex were to make flat topped top tree to accept any riser how many and what years could they cover with one tree top?
Would there be a market?.....say...perhaps..ngw members?
How about a selection of phater bars necked down to 7/8" at the grips and tree? They do it for hog ryders. why not metric?
Scott Ironhorse
