Copper Header Muffler gaskets for Gl1000 and Gl1100
Copper gaskets can be bought from NAPA; Fel-Pro part number 60567 . The automotive applications are 1976-84 Honda 1.3, 1.5, 1.6 and 1.8 liter 4 cylinder engines. May also fit some 1991-95 Nissan 4 cylinders. $1.49 each.
heraldhamster
Re: Copper Header Muffler gaskets
Post by heraldhamster »
not to hijack, but...
something I noticed and wanted to comment upon, when working on a customers 1200 a couple of weeks ago is that the copper squash gasket/rings between the head & header were a bit larger diameter than the 1000/1100. so there's a definite difference in outlet diameter on the 1200 heads as opposed to the heads on a 1000/1100 (which I believe are the same between the two).
someone I think recently mentioned the possibility of using 1200 header pipes on an 1100 or a 1000... or something like that? it seems the 1000/1100 headers might "fit" into/onto a 1200 head, but I don't think they would the other way, 1200 header pipes onto a 1000/1100 head.
somebody correct me if I'm wrong. I'm thinking the larger volume the 1200 vs. the 1000/1100 would warrant a larger outlet of the head exhaust and flow capacity of the 1200 header pipe. right?
H2G2=42
Thanks sunnbobb, I stole that one and put it in the crossover parts list collection.
Sidecar Bob
Post by Sidecar Bob »
The same gaskets also fit Suzuki GS400, CX/GL500/650 and probably a lot of other bikes.
BlueThunder
Post by BlueThunder »
sunnbobb wrote:Copper gaskets can be bought from NAPA; Fel-Pro part number 60567 or 12-1002. The automotive applications are 1976-84 Honda 1.3, 1.5, 1.6 and 1.8 liter 4 cylinder engines. May also fit some 1991-95 Nissan 4 cylinders. $1.49 each.
Granted I'm new to GoldWings and it may be obvious, but when posting cross over parts as above, can we specify what GW models they cover?
...Brian
1977 GL1000 - Ox
Re: Copper Header Muffler gaskets for Gl1000 and Gl1100
Good catch. Done.
Hoosier Daddy
Post by Hoosier Daddy »
Trying not to hijack, but along the same lines... but I noticed my Athena "complete gasket kit" came with metal rings that appear to be filled with asbestos, not the standard copper crush sleeves. I may swing by Napa and pick up a set of the Fel-Pro's if it's recommended.
rainstromrider say's I'm "addicted to the build"... I think he might onto something :)
oldthing
Post by oldthing »
The FelPro 60567 gaskets are pretty hard to come by through the Napa system, at least here in WA, so I've ordered a cross referenced Napa (EXH p/n31541) part to see if it's acceptable. It's not the copper type, it's got a metal inner crush ring surrounded by the asbestos-like stuff. I'll keep you posted.
___________
Happy riding,
Kirk
Hoosier Daddy wrote:Trying not to hijack, but along the same lines... but I noticed my Athena "complete gasket kit" came with metal rings that appear to be filled with asbestos, not the standard copper crush sleeves. I may swing by Napa and pick up a set of the Fel-Pro's if it's recommended.
The metal rings are fine. A lot of kits come with those. I wouldn't buy new copper ones just because of that. I'd use the metal ones and never give it a thought.
