CX500 motor in a CX650C frame?
Is it something that can be done with no custom work? I have a blown Engine in my 650.
Well at least I am pretty sure it is blown. It blows a bit of smoke and has much crankcase pressure. If you unscrew the oil fill cap it will shoot it across the garage as the threads pass the catch.
At one point I had a lawn tractor gas tank on it due to a bad tank for testing purposes. It ran great with this tank. But once I fixed the tank and used it, it ran horribly in general. Sometimes it would run ok but then start to run weak and die. It refused to start and sometimes wouldn't turn over till I release the pressure out of the oil cap. So I assume that its blown. Also think the tank fuel selector needs a clean out or replacement. The lack of power and eventual dieing acts like a fuel starvation issue that is also made worse by the crankcase pressure.
Is this idea even a good thing to try? Anything needed to know first? Any other good info appreciated.
Thanks
Thanks
Live free die well, er ride well and don't die trying.
83 GL1100 Interstate (just bought)
79 GL1000
R.I.P
78?(not sure about year) Yamaha 350RD (first bike in my teens decades ago)
82 Kawasaki Kz750
3x 80 Suzuki GS550
1x 81 Suzuki GS550LTD
82 GL500 Interstate (sold)
83 CX650C
78 GL1000 (parts bike, had to leave in WI)
78 CX500 (stripped for parts)
79 GL1000
R.I.P
82 Kawasaki Kz750
3x 80 Suzuki GS550
83 CX650C
Re: CX500 motor in a CX650C frame?
u would probably be better off getting that question answered here choppercharles.com/cs/
1981 CB750f --- sold
1982 CX500C --- finally sold -- fundage for the "wing"
1977 GL1000 --- gone
1976 GL1000 --- Sold
1977 GL1000 --- IMMMM BAAAAACK
Does your oil smell like gas? Do you park the bike with the fuel valve open? Is the fuel valve a vacuum operated one? The valve could be bad and letting gas continue to run through the carbs, past the rings and into the crankcase. Since you talked about it running fine with your test tank and acting up after you put the stock tank back on I am leaning towards that senario. Pull the oil fill cap off with the motor off and see if you can smell gas in the crankcase. You could also drain the oil and see if you get alot more out of the engine than it should normally hold. I have seen this before with other bikes. If that is it get the fuel valve/petcock rebuilt.
- the chef
- Location: Odenville,Alabama. The land of dixie! (!Hell yeah!!)
If you don't have a case of bad rings and you are getting blowby into the crankcase you may have a fuel in the oil problem ,,, you have to get in the habit of turning the gas off when parking and turning back on when starting .
Simply important.
Before I wrote it off do go get some fresh oil and change the oil making sure of the correct amount .
If your still getting pressurized crankcase then you need to do a rebuild . At least a hone and ring job.
If the engine is too damaged then it would be cheaper to get a new bike . For parts or vice versa...swapping.....
Simply important.
On the highway to Hell!
Ride on, Ride on.. !
PREVIOUS OLD LOVES=
19?? Zundapp with 6 hp Briggs and Stratton engine Chrome tank
1971 Kawasaki H1 500 blue /white stripe
1975 Honda 750 Yellow
1980 Honda Gl 1100 Interstate Black
1982 Honda Gl 1100 Standard Black
1983 Honda Gl 1100 Aspencade Black
1981 Honda Interstate Black
1981 Honda Gl 500 Silverwing . Candy muse red
1986 Honda VT 500C red
PRESENT RIDE >1976 Honda Gl 1000 Originally red, now flat black, olive drab, primer gray.
PREVIOUS OLD LOVES=
I actually suspected the gas issue as well. Forgot to mention that, but no gas in the oil and I learned the gas lesson the hard way on my first GS550. Those lil buggers love to drink the gas when sitting. It does have a vacuum line to the valve I had to block it off when I ran a test tank.
I do think one issue is a bad valve, but even with the test tank I got bad smoke and pressure in the lower end.
Thanks for the replies
79 GL1000
R.I.P
82 Kawasaki Kz750
3x 80 Suzuki GS550
83 CX650C
79 GL1000
R.I.P
82 Kawasaki Kz750
3x 80 Suzuki GS550
83 CX650C
has the bike ben sitting for awhile? maybe stuck rings?
Its highly likely its bad rings. I'm thinking its way more than I wish to get into at this point tho.
Shame tho since its a nice lookin bike minus the temporary patch job on the rusted bottom of the gas tank.
I just got a nice GL500 Interstate from a neighbor that requires far less attention. Fully drivable but needs a coolant system flush.
I think this is far more my style anyway. So I guess I'll be posting the CX650 for sale as is at some point.
79 GL1000
R.I.P
82 Kawasaki Kz750
3x 80 Suzuki GS550
83 CX650C
79 GL1000
R.I.P
82 Kawasaki Kz750
3x 80 Suzuki GS550
83 CX650C
- Purken
- Tin Member
I once let the oil get too low in my '78 CX500 and fried the engine. I bought a CX650 engine at Bent Bike thinking it would be easy to plug in; it wasn't.
When all was said and done the bike ran great and I was amazed at the difference 150 CDs can make.
Good luck w the 500
Paul
Good luck w the 500
Paul
-Paul-
1981 GL
2008 Stratoliner
1996 Supercharged Miata
1st Bike....1967 175 Bridgestone Hurricane Scrambler
1981 GL
2008 Stratoliner
- Zinc Member
If I remember well , abaut similar problem (650 IN 500 FRAME) problem is in front engine mount and ignition system. It can be done
A CX500 motor would be too much work because too many things are different, but if you get a GL500 motor complete with front engine mounts & radiator it will bolt in with only one mod needed. The final shaft (the one that the u-joint connects to at the back of the motor) is different so you will have to remove the back cover and swap in the one from your 650 engine. Since the engine will be out anyway, this should not take long - the hardest part will be cleaning the old gasket off.
Before I changed the engine, I would try soaking the cylinders with Seafoam or something like that to see if it is only a stuck ring, and failing that, have the offending head's rocker cover off to see if you can see the problem - you might just have a valve problem or a cracked head or something that and a good used head will fix.
- jinbtown
- Tin Member
Speedz wrote:Is it something that can be done with no custom work? I have a blown Engine in my 650.
Thanks
The 500 engine will fit with extensive modification to mounting, as the frames are very different. The fellows (myself included) can answer this over at choppercharles.com probably better than here, but long story short, unless you are willing to do some fab work, no, you're better off finding a salvage 650 bike or parting out the rest of your 650
Alternatively, I believe the GL engine might fit as those also have similar mounting points. IIRC there are a few things to be done still when taking this route as well.
1981 CX500C - Sold!
1982 GL500I - Sold!
1982 GL500 - Backed over by a big truck. Sold!
83 GL650 Interstate
78 GL1000 (being parted out...)
90 VTR250
1982 GL500I - Sold!
83 GL650 Interstate
90 VTR250
Yeah, we didn't mean this little forum to be an in depth resource for CXs.
Chopper Charles' is the PLACE for that.
