Calling all 1000's with a Weber carb..
- katmol
Ok guys, everybody that's running a 32/36 Weber carb on their GL1000, what jeting is working best for you?
Old Naked Wings and SOHC 750's
Re: Calling all 1000's with a Weber carb..
Don't know if many will respond, as most are running 40's..
- 78AZWing
I think mine are what is called for in the CI installation manual.
A PO did it, and it runs fine so I haven't looked to see what they are.
http://www.goldwingdocs.com/index.asp the first item under GL1000 manuals.
For that run-down feeling -
Try Jaywalking!
1978 'Wing with Weber conversion, UnDressed
1976 Junkyard 'Wing with a Dyna ignition. Otherwise undressed.
Proud member of the "NGW CARTEL"
Try Jaywalking!
Sure it's not a Holley?
My friend a long time ago ran a WEBER 32/36 with the following jetting,.....primary slow jet 60-65, secondary slow jet 50, primary main jet 135-140 (he ran a 137 but wanted to run a 138), secondary main jet 140, air jets are 170 primary 165 secondary. Just keep in mind this was for his setup and might differ from yours but it's at least a starting point to do some fine tuning!!!! Let us know how it turns outBob
Robert White
- 78AZWing
Yup.sunnbobb wrote:Sure it's not a Holley?
Weber 28/30 progressive mounted on one of the watercooled/heated manifolds like this one. These picture comes from Randakk's excellent site on the early wings. Please don't bother him about them.
Try Jaywalking!
Try Jaywalking!
- Tin Member
I have a Holley 5210c (a weber 32/36) that I will install this summer. Still need to get a manifold for it. Thinking about the type 3 and 4 adapter for around $40. Would LOVE to have a manifold like the one above.
- vagrant50
Badorderbob
What bike did he have that set up on?
Brent
Brent
I can build anything you can afford!
http://community.webshots.com/user/vagrant50
- taunusrainer
The manifold in the pics came with a weber. It was me who was the PO of this beauty before I traded it to Randall.
I still have the carb here, if needed I can disassemble it and find out the jetting. PM please.
Ray
Ray
1976 GL1000 test mule
1977 GL1000 in parts, rebuild in progress
1969 Ford 17m 2.3V6
1976 Ford Cortina 2.3V6 (Propane)
1990 Mustang 5.0 7up conv.
1998 Peugeot 406 Coupe (Propane)
1969 Ford 17m 2.3V6
- katmol
taunusrainer, that would be great if would do that!!!
taunusrainer wrote:The manifold in the pics came with a weber. It was me who was the PO of this beauty before I traded it to Randall.
Ray
Hello Brent, as many times I read this post I missed your recent post (Sorry) !! The manifold was one of taunusrainer's design,......http://backyardbuiltwings.multiply.com/ ... 4,.....and was on used on this bike,.....http://backyardbuiltwings.multiply.com/ ... s_Pictures,....... The bike was an 83GL. Hope this helps!! Bob
Robert White
- vagrant50
The 32/36 on my 87 manifold has the jets that came in it. As follows.
Primary Idle Jet .55 mm
Secondary Idle Jet .50 mm
Primary Main Jet 1.4 mm
Secondary Main Jet 1.35 mm
Primary Air Corrector Jet 1.65 mm
Secondary Air Corrector Jet 1.6 mm
It's a 1200 but it ran well right out of the box.
Brent
Brent
- katmol
What are the jet size numbers that cross to the mm?
vagrant50 wrote:The 32/36 on my 87 manifold has the jets that came in it. As follows.
Brent
