Anyone running LDWingnuts single carb?
I ordered one of these complete kits and installed it on my Aqua 75. It was a fairly straight forward task, fired right up but absolutely will not idle, won't even try. I have rechecked all possible vacuum leaks all are tight. Runs very strong up to about 90 might go further but I dont care to. Would like to hear from anyone else wh has this setup on ther bike....
1975 GL1000 single carb setup
1975 GL1000 possible bobber in near future
1980 CT110 just for fun
- lcallison
Re: Anyone running LDWingnuts single carb?
I don't have one, but my brother does on his 79. He had to advance the timing a good bit to get it to idle right. I have one of his manifolds and a solex 30 carb that I'm eventually going to try on my 1100.
Larry
84 GL1200A
79 GL1000
84 GL1200A
79 GL1000
Im happy with the overall performance of the setup, I have ordered a clear timing plug so I can play with the timing with a strobe, I am also running a Dyna setup with 2 into 1 Jardines on it now.. accelerates much stronger than with the stock setup IMHO
- morganfrmn
- My Album: http://www.ngwclub.com/gallery/main.php?g2_itemId=2743
I have a single carb system on the general lee, (photo to the left) It works great I also have an electric fuel pump...no complaints, I dont know the name brand.
Click here and you can see my motorcycle
(http://www.ngwclub.com/gallery/main.php?g2_itemId=2743)
(http://www.facebook.com/morganfrmn)
what type of electric pump you running? I am getting ready to order one from Randakk....morganfrmn wrote:I have a single carb system on the general lee, (photo to the left) It works great I also have an electric fuel pump...no complaints, I dont know the name brand.
- 78AZWing
Try using this to set yours up. http://goldwingdocs.com/index.asp Click on Cycle Innovations Installation and Troubleshooting Guide Hope it helps.cc1911 wrote:I ordered one of these complete kits and installed it on my Aqua 75. It was a fairly straight forward task, fired right up but absolutely will not idle, won't even try. I have rechecked all possible vacuum leaks all are tight. Runs very strong up to about 90 might go further but I dont care to. Would like to hear from anyone else wh has this setup on ther bike....
For that run-down feeling -
Try Jaywalking!
1978 'Wing with Weber conversion, UnDressed
1976 Junkyard 'Wing with a Dyna ignition. Otherwise undressed.
Proud member of the "NGW CARTEL"
Try Jaywalking!
Thanks for the link, I will check it out...78AZWing wrote:Try using this to set yours up. http://goldwingdocs.com/index.asp Click on Cycle Innovations Installation and Troubleshooting Guide Hope it helps.cc1911 wrote:I ordered one of these complete kits and installed it on my Aqua 75. It was a fairly straight forward task, fired right up but absolutely will not idle, won't even try. I have rechecked all possible vacuum leaks all are tight. Runs very strong up to about 90 might go further but I dont care to. Would like to hear from anyone else wh has this setup on ther bike....
Gonna move this over the to customizing carb section
Thanks, guess I should have done that at the beginning.......Whiskerfish wrote:Gonna move this over the to customizing carb section
- Cookie
- RIP: 1950-2011
You won't believe how much you have to advance it.
I'm waiting for my clear plug to arrive so I can see what is going on with the engine running....Cookie wrote:You won't believe how much you have to advance it.
- randakk
- Early 'Wing Guru
Here's what I learned when I tested this conversion:
http://www.randakks.com/Review%20of%20L ... ersion.htm
Did you cap the vacuum port on the carb? It is not needed on a GL1000. That fact was not mentioned in the instructions provided with the kit.
Are you aware that on a Solex carb, the idle mixture screw controls "air" not "fuel?" So, lean/rich adjustments are "backwards" compared to the OEM Keihin carbs.
Randall Washington (Randakk)
Retired Founder - www.randakks.com/
Curator - www.facebook.com/groups/CarburetorAppreciationSociety
Thank you for reading my post, I actually read your account very closely and ordered a master carb kit and video from you (which I am still working on) I bought this setup to put on my other 75 when it is finished, just going to be a daily driver and was looking for simplicity on this one. Since the carbs are off on my Aquq bike (found a broken float bowl support I decided to install and run the single carb temporarily.randakk wrote:Here's what I learned when I tested this conversion:
I did plug the port as you suggested in your review but the curb idle screw has absolutely no effect, it just will not idle as of yet. I have checked and rechecked for vacuum leaks, the carb actually starts and responds well though.
- randakk
- Early 'Wing Guru
If you have "no idle" that a bit strange. I found various aspects "sub-optimal" but it delivered a reliable idle...probably it's best feature.
Check to make sure your choke is working correctly (especially if you have an automatic choke carb). I suspect you have some sort of carb problem that is preventing a good idle. An example would be a blockage in the idle circuit.
These are very simple carbs and there's not much that can go wrong but used ones are often worn out.
I just came in from the shop where I was going over this setup with an eagle eye, low and behold I found that the curb idle screw was not making contact with the fast idle cam so a slight tweak and now it idles...should have paid closer attention to detail.. the carb was new in a box so I just gave it a quick check before installation. Now if I can just figure out why the two back cylinders are running rich.....
