82 GL500 questions
KDS111
82 GL500 questions
Post by KDS111 »
Hello all,
This weekend I'm picking up an 82 GL500 SilverWing.
It runs fine, 10,000 miles.
This is my first Silverwing so bear with me.
There is a little leak of antifreeze running down the left side of the motor.
It looks like its coming from the top rear of the motor. This is the thermostat or water pump assembly correct? How involved is this.
I have the Honda service manual. Not a lot of pictures and diagrams.
Does anyone have a link to get the Haynes manual?
Thanks as always for all the great advice.
Thanks, Ken
1979 GoldWing GL1000
1982 GoldWing GL1100 (Naked)
1982 GoldWing GL1100 Aspencade
1985 GoldWing GL 1200 Aspencade
1980 Suzuki GS850GLT
1982 Honda GL500I SilverWing
mildhog
Zinc Member
Zinc Member
Re: 82 GL500 questions
Post by mildhog »
Arnie in VA
In the stable:
81 GL1100, 82 GL500I, 83 GL650, 81 Gl500I, 82 GL500
mildhog
Zinc Member
Zinc Member
Post by mildhog »
May be coming from the weep hole in which case you'll need to replace the mechanical seal.
http://globalcxglvtwins.hostingdelivere ... f=17&t=525
Arnie in VA
In the stable:
the chef
Location: Odenville,Alabama. The land of dixie! (!Hell yeah!!)
Post by the chef »
THERE IS A CHROME COOLANT TUBE THAT RUNS AROUND AND UNDER THE LEFT CYLINDER TO THE REAR OF THE ENGINE , PROBABLY LEAKING FROM THAT REAR CONNECTION.
On the highway to Hell!
Ride on, Ride on.. !
PREVIOUS OLD LOVES=
19?? Zundapp with 6 hp Briggs and Stratton engine Chrome tank
1971 Kawasaki H1 500 blue /white stripe
1975 Honda 750 Yellow
1980 Honda Gl 1100 Interstate Black
1982 Honda Gl 1100 Standard Black
1983 Honda Gl 1100 Aspencade Black
1981 Honda Interstate Black
1981 Honda Gl 500 Silverwing . Candy muse red
1986 Honda VT 500C red
PRESENT RIDE >1976 Honda Gl 1000 Originally red, now flat black, olive drab, primer gray.
mildhog
Zinc Member
Zinc Member
Post by mildhog »
the chef wrote:THERE IS A CHROME COOLANT TUBE THAT RUNS AROUND AND UNDER THE LEFT CYLINDER TO THE REAR OF THE ENGINE , PROBABLY LEAKING FROM THAT REAR CONNECTION.
I would most certainly check that first. Easy stuff first, always. I'm usually not that lucky.
Arnie in VA
In the stable:
KDS111
Post by KDS111 »
I'm also not that lucky.
I can sure use all your help.
Thanks, Ken
