Side covers ideas ?
9Ball
Rusty Probie
Rusty Probie
Side covers ideas ?
Post by 9Ball »
Hi new here and recently picked up a 650 Silverwing , real pumped up about this bike.
side covers are broke , dont realy like them anyhow.
had an idea of welding studs on frame where gromets are and trying to use spacers
and a plate ,
bit ignorant whats best way ? something new but realy lucked out finding this bike
Thanks
Paxton Gomez
My Album: https://picasaweb.google.com/1039177310 ... 0CAFERACER
Re: Side covers ideas ?
Post by Paxton Gomez »
9Ball;
Welcome. This is a GREAT club. You'll enjoy communicating with kindred spirits... confused22
I too, don't like the side covers on my CAFE... censored2 Here is what I did. :eyes :horn
SEE PHOTOS: https://picasaweb.google.com/1039177310 ... 3vvZ18rKdA
I hope it helps. anim-cheers1
"If only they would all just leave me alone with my old cars and my motorcycles, I would be content to let life, and the world pass me by"
J. Paxton Gomez - Paxton.Gomez@Gmail.Com
County of the Fallen Angels. Ca. 91206
toys...
'66 (ALPHA) Bronco
'77 GL1000K2 NGW CAFE Racer
'00 GL1500CY-Valkyrie 6-Cyl/-6 Carbs/1532cc
'02 VTX1800R2 V-Twin-FI/1795cc
'07 Chevy Colorado Crew Cab
https://picasaweb.google.com/103917731019176896112/TheThreeAmigas?authkey=Gv1sRgCIe0wJLpibP_ZQ
I'm going to move this to the GL, CX forum. You may get better responses there with this one.
FADM Stern GNSF
Post by FADM Stern GNSF »
agree with robin1731, go and check on the GL/CX forum, as people are always parting bike parts there, and you may be able to pick up a replacement set. I have seen people there selling them in the past
1979 GL1000
1982 CX500C
If you haven't already, check out
http://choppercharles.com/
Sidecar Bob
Post by Sidecar Bob »
I guess this is better late than never:
If the pins on the side cover are broken you have 2 options:
1) Either glue the pin(s) back on with some sort of epoxy or form replacements from something like epoxy putty
2) Add studs to the frame, drill holes in the covers and fasten them on with acorn nuts. The studs could be bolts welded on but I prefer to use 5/16" threaded rod through the frame from side to side (the holes that the pins are supposed to go into are opposite each other in the pressed steel part of the frame and the space between them is enclosed) with nuts & fender washers on either side of the frame and more a nut near each outer end for the acorn nut to tighten against. If you curve the threaded rod so that the ends are perpendicular to the surfaces of the covers the acorn nuts (I use stainless but you could use chrome) & their washers will sit flat against the covers and look natural. I prefer this method because they absolutely can not fall off as you go down the road and nobody can steal them without tools.
