will gl1200 forks fit a 78 gl1000?
baci
My Album: http://www.ngwclub.com/gallery/baci
Post by baci »
Any one ever swap these in? Need a new tree?
Baci, RoninMC
"Ride...Ronin, RIDE!"
78 gl1000 daily rider
'79 Vespa P200E project scoot
Re: will gl1200 forks fit a 78 gl1000?
the tubes are bigger in diameter so it is not a direct cross. Will require new trees.
A Wing and a Chair
Lead Member
Lead Member
Post by A Wing and a Chair »
I have gl 1200 forks on my 81 gl1100. I used 1500 fork tubes and lower clamp, 1200 top clamp, 1100 stem, 1100 fender, 1200 fender brackets, 1200 legs rim and brakes, 1500 progressive springs, I used these parts because I had them here but I believe the 1200 lower clamp and stem would fit. Doing this on a 1000, The stem and bearings would be the part that may have to be changed.
Doug McCracken
Holy multi-cultural Goldwing!!!!.
