Wingman
- Markn
- Zinc Member
- My Album: http://031sink.blogspot.nl/
Wingman
So it's a 1977. Here are some pictures of it's current state:
Having some problems making a custom filter (advise/tips?).
For the electric, i made it start with the key. So the only button on the bike i'll need is for the light.
(i do not have turning signals).
Some things to do:
-Find/make air filter.
-Find/make fuell tank.
-Give it a nice rearend.
-Small work.
Some things to do:
-Small work.
1979 KZ Daily bike http://www.ngwclub.com/forum/viewtopic.php?f=15&t=45291
1977 K2 ''Wingman'' project http://www.ngwclub.com/forum/viewtopic.php?f=16&t=45292
- Placerville
Re: Wingman
Welcome from California and to the NGW. You're the second new member from the Netherlands today! It appears that you've jumped into your project head first and it's looking good. Interesting that you don't need turn signals? Good luck with your project!
- Markn
- Zinc Member
Re: Wingman
It's a dutch rule only for ''oldtimes'' (before 1980's).
When it doesn't have turnsignals than its ok. But if you even have a button for it on your bike, it needs to work complete.
- Placerville
Re: Wingman
Got it. They do the same thing in California.... Prior to a certain year, an 'always on' headlight isn't required.
- Markn
- Zinc Member
Re: Wingman
So i have 2 burning questions:
- What to do with the airfilter, my single top-tube is to low to fit the standard air filter. I couldn't find some examples yet.
- Does anny one ride with a open belt? It looks cool, but sounds like a bad idea. Maybe some alternative?
Re: Wingman
There are some guys on here that have run open belts for a lot of miles with no problems.
On the air filter. I took a stock filter housing. Cut everything off of the base just above the flat part that sets on the chamber. Got a small round filter for a car (aftermarket I think about 8" in diameter). That filter came with a chrome base and top. I used the top on the filter. Cut the stock base to fit the diameter of the element. The draw back is the jetting is off when you do that. I ended up putting a stock air box back on it.
- Markn
- Zinc Member
Re: Wingman
Hey, i also tried almost the same thing, with the same problem.
So i just had a new idea, a few day's ago i ran into a K&N employee. He told me they could make everything.
So i was thinking to lower the intake, than use the bottom of the body.
And let K&N make a custom open filter. (Like the picture below. usual size with a piece taken out).
Hope to find some other (working) solutions. Before i spend my little cash on this.
Re: Wingman
I think a cut down stock air box would be the way to go. If they can make a filter to fit without being to pricey that would work too. Better than trying to make your own.
BearWing
- Markn
- Zinc Member
Re: Wingman
To keep it short, We can do every thing. As long the values on the papers are correct.BearWing wrote:What kind of inspections are required in the Netherlands? And, welcome, of course!
My bike is by paper still on the road, so that is no problem.
For the inspections to get the papers, i wouldn't know. But i guess the usual safety checks, lights, exhaust....
BearWing
Re: Wingman
Thanks. Here in Kentucky, if you can bring in a VIN headstamp attached to two wheels (which don't necessarily have to match, or even be round), it's good.
Re: Wingman
You may want to see the solution that Nate used on Bones (Building of Bones in the custom section) Just do not try to lower the restriction and it should work out fine but boy it looks tight in there.
- Greg
Re: Wingman
My theory is ,if you going to restrict the intake flow to the engine than you should be able to get away without having to re jet by expanding on the rate flow out of the exhaust. .One way might be is by removing the baffles or with a more free exhaust flowing muffler.. Just a thought.
- Markn
- Zinc Member
Re: Wingman
Fred, i found Nates solution. Look like a great idea, and nice to know it works (and can be done)! Thanks.
Greg, i'm going to do the 4-into-4 Exhausts. Hope that will do
like this only shorter;
- Greg
Re: Wingman
Markn wrote:Fred, i found Nates solution. Look like a great idea, and nice to know it works (and can be done)! Thanks.
Greg, i'm going to do the 4-into-4 Exhausts. Hope that will do![]()
Yea Man, that’s the ticket.
