The method for bench syncing the carbs has previously been to use a wire or needle as a feeler gauge between the throttle plate and carb body. But, when Mike Nixon, noted GL Carb Guru joined this board he brought to my attention that the wire/needle method can cause "nicking of the throttle plate which permanently ruins the plate and introduces unregulated air." And you know that he's seen the guts of enough of these carbs to know what he's talking about.
So, how to get a decent bench sync?
Simply look into and around the outlet port of #3 carb and locate the bypass outlet. It will be right along the line of the resting butterfly.
[attachment=0]GL1100_carb_wm.jpg[/attachment]
Note the relationship of the outlet to the edge of the butterfly. Now, adjust the 1/3 sync screw so that #1's butterfly position matches #3.
Flip 'round to the other side and adjust #2 and #4 so they match each other. The 2/4 sync screw is between those two carbs.
Lastly, adjust the left bank's sync screw so the 2/4 set matches up to #3. The side-to-side sync screw is aft of #4 carb.
Thanks to Mike Nixon for the info and pic!
Carb Bench Sync
Carb Bench Sync
- zavikan
Re: Carb Sync
That's how I did mine. I am by no means an accomplished or talented mechanic like many on this board....but I just saw that as the obvious solution.
I wonder how many small nuggets of insight like that is unspoken from the minds of the average. Simply because we didn't think it was worth mentioning...
Good to have it out tho!
'76 Goldwing GL1000 33k
'77 Goldwing GL1000 53k SOLD
Re: Carb Sync
all ideas and shortcuts, or home remedys are wroth mentioning. i learn something new almost every day on this site
- Irishman1
Re: Carb Bench Sync
After reading this I just looked at the 1100 Carbs on Ruth's build and they were all way off! Didn't think my carbs had the ports at first!! Thx
In the garage:
1975 Honda gl1000 sulfur yellow( my first!) NGW BOTM February 2020
1975 Honda gl1000 red (Ruth's free bike) NGW BOTM January 2017
1975 honda gl1000 red. Eariest of my 75's 2/75 date
1975 Honda gl1000 blue green 5/75
1975 Honda gl1000 blue green 3/75
1975 Honda gl1000 blue green 4/75
1976 Honda gl1000 sulfur yellow
1977 honda gl1000 red black, Ian's next bike
1976 Honda gl1000 red next restoration
1975 Honda cb750 rebuilding soon!
1975 Honda gl1000 2/75 blue/green
1978 Honda cb750f super sport
1979 Honda cb750f super sport
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
"I really need a BIGGER garage!!"
"I got a bigger garage!!!!
" ride'm, don't hide'm!!!
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
