water pump
- rooster4321
water pump
75 gl1000 I am replacing my water pump and read all the shop talk about it . Ordered new pump and gasket kit. Its recommended to replace the Phillips head screws with hex, is there a source or just ace hardware? also should they be steel, stainless steel or aluminum? what kind of lube for the o rings and or gaskets?
Re: water pump
Robin has them. http://www.ngwclub.com/forum/viewtopic. ... ts#p584090
Re: water pump
You can get them at any good hardware store.rooster4321 wrote:75 gl1000 I am replacing my water pump and read all the shop talk about it . Ordered new pump and gasket kit. Its recommended to replace the Phillips head screws with hex, is there a source or just ace hardware? also should they be steel, stainless steel or aluminum? what kind of lube for the o rings and or gaskets?
I got all mine at the local Ace.
I went with stainless.
78 GL1000 Original Owner 131k
Re: water pump
Just use caution when tightening them. Using hex head it is very easy to over tighten them and strip out the case, Also over compressing the front cover gasket can result in shift linkage binding.
Re: water pump
If you use a torque wrench properly can you still do that?Whiskerfish wrote:Just use caution when tightening them. Using hex head it is very easy to over tighten them and strip out the case, Also over compressing the front cover gasket can result in shift linkage binding.
- Placerville
Re: water pump
In addition to the ShopTalk thread, I recommend reading Randakks thread on the subject. Pay particular attention to the 'Bingo method'. It works. You have your answers above regarding fastener replacement. Any type of lube will work fine including Vaseline. I lubed all of the O rings and gaskets as well. Some will say gaskets 'dry'. That's their preference. When you insert your new pump, be careful not to pinch the O ring. Lube all surfaces. Don't miss the 8.0 X 1.9 O ring around the dowel in the upper right corner. It's critical. Use a 'Diagram' as seen on Randakks site to keep track of your parts. Very helpful.rooster4321 wrote:75 gl1000 I am replacing my water pump and read all the shop talk about it . Ordered new pump and gasket kit. Its recommended to replace the Phillips head screws with hex, is there a source or just ace hardware? also should they be steel, stainless steel or aluminum? what kind of lube for the o rings and or gaskets?
Re: water pump
The trans cover bolts are 6mm. Standard torques on that size bolt is ~90 lbs-in. Use that and you should be good. There is a range usually from about 80 to 100 or so. But stay with 90 for all 6mm and you'll be happy. And use a good torque wrench. Also, use anti-seize on stainless steel bolts going in the aluminum.
- Placerville
Re: water pump
Consider having your tank cleaned and pressure tested by a radiator shop. The metal on these tanks is thin and the 'in' and 'out' coolant tube joints take a lot of abuse from PO's replacing hoses. Ask the shop to re-solder those joints.
- 77Pinto
Re: water pump
I would not, but if you do be sure to put an anti seize on them!!SnoBrdr wrote:
.....I went with stainless.
I have used the Honda bolts for the later bikes, fit like they are made for the job, no worries.....
Bill
1976 GL1000 LTD (X2)
1976 GL1000 Sulfur
1977 GL1000
1976 GL1000 Sulfur
1977 GL1000
- RIP: cookie
Re: water pump
And note that Robin is quoting torque in INCH/pounds ..... not foot/pounds .....
- rooster4321
Re: water pump
All good advice guys thanks, I shall be diligent when I put this back together hopefully this week.
- rooster4321
Re: water pump
I got the new water pump, gasket kit from ebay and bolts from Robin, thanks, Put it all back together with all this great advice and wahoo no leaks and 400 miles in 2 days latter no problems. Thanks all, this is the best site.
- 7 Replies
- 822 Views
Last post by gregforesi
- 404 Views
Last post by chewy999
- 12 Replies
- 867 Views
Last post by CYBORG
- 17 Replies
- 1185 Views
Last post by Don R
