Charging System
- northwood
Charging System
Hey guys, I have obviously talked dirty to my girl. She did not want to start this morning. Battery I think has gone kapoot.
Idle charging 13V
3k rpm + charging is 15v
What is the range on the charging system for the GL1000?
Thanks!
Idle charging 13V
Thanks!
2015 Honda Grom (Soon)
2006 Honda VFR800 "Snowflake"
2007 Honda "Chicken Bacon Ranch" (CBR1000RR)
Previous Bikes:
1975 Honda "ol' Bird Dog" GL 1000 (Gone but not forgotten)
1982 Kawasaki AR80 (The one I will regret selling)
1982 Honda CM450E Not so Project "Connie"
1987 Yamaha Virago XV535
2005 Triumph Daytona 650
Previous Bikes:
Re: Charging System
Sounds like you are in the ball park. A little high in both ends. Have a load test performed on the battery. Beyond that check the regulator
- northwood
Re: Charging System
Thanks Cyborg!
Previous Bikes:
Previous Bikes:
- rod willis
Re: Charging System
charge your battery and then recheck you may not be running
it enough to keep the battery fully charged
Rod
Rod
rod willis
1976 GL1000
1976 GL1000
- Toehead
Re: Charging System
If you are charging consistently over 15V, that negatively impacts battery life.
You really want to be closer to 14.7
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
1980 CB750C (sold)
Re: Charging System
I would also double check your readings with another meter
- scootsx2
Re: Charging System
If the other meter also shows higher than "normal" voltages, be sure to check your ground connections as well.
1975 GL1000 Sidecar Outfit
2001 GL1800 MotorTrike
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
- theburgundian
Re: Charging System
And don't forget to check the regulator (its role is to evacuate the surplus of the electricity made by the alternator if I remember well)
Always look on the bright side of life buddy
- jdvorchak
Re: Charging System
engine off key off 12.6+ (13 + would be indicative of a fully charged new battery)
key on engine at idle 13.2+
key on engine at 3k rpm 14.2 to 14.8
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- northwood
Re: Charging System
Yea, I think my battery is fried. Plus the voltage regulator is out. I charge it out of the bike and install it and the battery will crank it over once then it no longer has enough juice. I can't check the charging system until I get that fixed. I am with jdvorchak. It is at 15v, which is just at the limit. Currently looking for a voltage regulator and a battery.
Previous Bikes:
Previous Bikes:
- Toehead
Re: Charging System
One thing that is relatively common is for the regulator to get an incorrect reference voltage. Since the regulator is external, it is reading the battery voltage via a black wire that has several connections. If these are corroded, you can get a voltage drop. The end result is that the voltage regulator allows more charge voltage to compensate, and you cook your battery.
With this bike running, read the voltage going into the regulator on the black wire. if it is equivalent to battery voltage, this isn't your problem. If it is 14.7 while the battery is 15V, you have your culprit.
A good fix is to upgrade to a rectifier with an internal regulator. Much more reliable.
1980 CB750C (sold)
1980 CB750C (sold)
- 21 Replies
- 962 Views
Last post by gdonlo04
- 3 Replies
- 466 Views
Last post by Track T 2411
- 8 Replies
- 560 Views
Last post by adecood
- 8 Replies
- 527 Views
Last post by Easter
- 14 Replies
- 951 Views
Last post by wolf_walker78
