how resistant to backfiring is Tom Langdon's 2 barrel?
frankshetler
Post by frankshetler »
I really hope it's bullet proof
I'm in the middle of a nightmare trying to figure out why the tfi units and fancy coils so highly recommended by a huge crowd are attempting to destroy my engine
Explosive fireballs blasting through the carb.
Can't be good for anything
But is it destroying things in that progressive 2 barrel Carter from Langdon's?
I sure hope I can get this thing cleared up and go ride the thing.... bleh
78 GL1k
Aka Rat Trap
Re: how resistant to backfiring is Tom Langdon's 2 barrel?
I have no idea on that carb. But if you have backfiring through any carb like that I'd go back check the wiring on the ignition. Sounds like something might 180 degree's off. Or plug wires crossed.
Slabghost
Post by Slabghost »
No carb I know can handle that forever but the two barrel weber is more tolerant of that than the stock rack would be. Some have actually blown the tops off one or more of the slides. I agree something is wired in correctly in the ignition. Double check all your ignition wiring. Could be you are firing the coils backward or the plug wires are on the wrong plugs.
Genius has it's limits. Stupity does not!
80 GL1100 dresser, 81 Gl1100 w/fairing and rack, 82 KZ750ltd, 78 KZ750 twin,
78 KZ650 basket case, 82 KZ650 in progress, 82? Seca750 not running, 85 Virago 700,
84 Vulcan 700, 75 CB200T, A couple extra motors.
What's MBS?
frankshetler
Still further investigation pending but it seems the solid core spark wires and high juice coils may have been interfering and false triggering the tfi modules I put in.
As soon as I get an alternator alignment issue straightened out I'll be back at it.
I've been told to put some resistors between hot and the trigger leads to make it less vulnerable.
78 GL1k
Aka Rat Trap
