Convert 1000, 1100, 1200 to EFI using ST or CT 1300 system
sportwing
Post by sportwing »
Has anyone tried modifying the Honda ST or CT 1300 to use on the Gl 1000, 1100, or 1200"s.
Could injector bungs and hold down brackets be added the GL intake elbows, with custom fuel rails, re-map the Honda computer and all other needed fabrications or modifications? These are some of the terms I have heard while reading about EFI conversions. What would it take or is it even possible?
Re: Convert 1000, 1100, 1200 to EFI using ST or CT 1300 syst
I'm sure its possible. 1200 already has an EFI model. Anything is possible with enough time...and money
