water pump kit
water pump kit
I noticed on ebay there are water pump seal and bearing kits for sale, has anyone tried to rebuild one or is it just better to buy a new pump?
Re: water pump kit
I rebuilt three of them yesterday. Not that hard, and its really a pretty simple design. I guess you have to weigh the cost of the kit against the cost of the kit, and your time
Re: water pump kit
Yep, rebuilt one using that kit. If you are careful, they work good as Cyborg said. You have to be careful with the impeller...it is a fragile little bugger!
Re: water pump kit
Fragile for sure. I dropped one of my pumps, and it broke. So I now have four good pumps, and a small box of pump extra parts
Re: water pump kit
Yep! When I did mine, I had a foam pad directly below the work space...just in hopes if something fell, it would hit that a couple inches away vs the concrete floor. Didn't trust doing it on the bench, so sat on the floor.
- scootsx2
Re: water pump kit
I just replaced a water pump last week. Just buy a new pump and the associated gaskets and seals IMHO.
1975 GL1000 Sidecar Outfit
2001 GL1800 MotorTrike
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
Re: water pump kit
The water seems to have stopped leaking since I got it running, the oil not so much. I'm holding off on the pump until I correct the missfire that has defied all my attempts to diagnose. My mechanic buddy thinks it's a sticky valve.
- Toehead
Re: water pump kit
I don't know the history of your bike, but I would think carb issues are far more likely.
Do you have a topic for the misfire issue?
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
1980 CB750C (sold)
Re: water pump kit
I didn't start a separate topic yet. it's probably time to do that, I wanted to try everything I know how to do before asking. Timing belts are on the way, I didn't want to run it after I discovered what could very well be original belts.
Thanks.
Thanks.
Re: water pump kit
A lot of time pump leaks will resolve themselves once summer arrives and the bikes get used frequently again. Both of mine leak a bit in the winter but are just fine all summer and have been that way for years. Same with the crossover tubes. When it is cold a bit of seepage there is not a cause for alarm to me anyway.
- RB
Re: water pump kit
I have lots of pump parts too..even one good bakelite impeller..anyone want to buy it?? Note the metal impellers and Bakelite take different rebuild kits..I think the bearings are different???
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
Re: water pump kit
That is correct. They take different kits
