80-81 gl1100 vs 83 gl1100 engine
Otis76
Post by Otis76 »
Hi.. What is the difference on these two engines??? Can a older 1100 be used in a 83 1100???? Whitout hassle?? My engine said goodnight few days ago.. The primary chain broke and destroyed atleast one sprocket.. What is the difference in parts. Thanks
Re: 80-81 gl1100 vs 83 gl1100 engine
The 83A I think it was has overdrive. Other than that I think the only difference is the jets in the carbs are movable in the 82-83. Maybe some minor stuff but nothing to stop an engine swap.
Otis76
Post by Otis76 »
Wich mens i can Use the carbs from mye 83 on a older engine???
KYpondman
Post by KYpondman »
The engine to secondary drive was changed on the 83 to reduce engine RPM at speed. 1st gear was made lower to compensate on take off. the result of this is the 5th gear on the 83 is now an overdrive. I think you'll find with the 81 engine you will be running about 500 rpm higher in 5th at highway speeds.
Claude
Otis76 wrote:Wich mens i can Use the carbs from mye 83 on a older engine???
Yes
Steve81GL1100
Post by Steve81GL1100 »
On my 81 60mph = 4000 RPM in 5th... Then again, it's right on the cams at that speed so ready for a burst to pass without a downshift.
I read in the 20th Anniversary Goldwing book that the 80-81 were the lightest and quickest GLs made. Quickest must mean only for the 4-cylinder bikes though...
Steve
Steve
1996 BMW R1100R
Yes
Yup, no problems.
Otis76
Post by Otis76 »
Is this a 1000 or a 1100??? Help!!!
HotFoot
Post by HotFoot »
And the clutch for 1100's.... when did the change to hydraulic actuation happen?
Also location of the neutral switch?
Hoppy
'81 Honda GL1100 Std
'80 Honda CX500D
'79 CX500C (Stagnant Project)
Ever Growing SHOP (Shameful Hoard Of Parts)
The Past: Triumph, Norton, BSA, Honda, HD, Kawasaki
Old Fogey
Post by Old Fogey »
No Hydro clutch on the 11s, all cable. Neutral switch changed to the front cover in '83 model
Yeah, 1200 was the first for Hydraulic clutch from Honda.
Otis76
Post by Otis76 »
So it is kinda a upgrade to put a older engine in.. Since it might be more responsive gearvise??
It should be. Even though the 80-81 had a higher first gear, they were mated with a 17" tire. Your 83 will have a 16" tire. You'll just gain a few extra rpms in 5th gear. They should be pretty close.
Earl43P
Post by Earl43P »
Old Fogey wrote:*SNIP* Neutral switch changed to the front cover in '83 model
Ummmm, no. The 82 had the neutral switch on the front cover, single wire. Mine is a Standard. (Also came with self-canceling turn signals, which means the speedo has a two wire speed sensor added.)
83 (my 83 donor was an Interstate) picked up an OD indicator light in the speedo, so the neutral switch had two wires, not one.
Can't speak for other years/models.
2008 GL1800 "yawn"
KTM390A “Hootinanny”
04 ST1300 DDDD (Double darksided daily driver) Sold 4/2022
93 GL1500I Double darksided and SOLD 3/29/20.
99 Valkyrie IS, Fast Black Double Darksided
"Fishtailed, flipped and flung me, but wearing it well". Sold!
82 GL1100 retired DD, needs work.... Sold 3/3/17
