https://ngwclub.com/forum/viewtopic.php ... 81#p828672
air cooled flat four VW bug engine builders
fish
Post by fish »
all this talk about bearings...
I wonder if there is anybody out there who has performed "Line Boring" on the air Cooled VW engine cases.
Someone who has done this and also split the cases on a goldwing would have the experience to answer some questions
I wonder if the goldwing cases could be line bored to fit some other bearings.
I wonder if the goldwing crank journals could be turned down to fit some other bearings?
:-D
Timothy Mark Fisher
Catalina Arizona
Re: air cooled flat four VW bug engine builders
My understanding is that the goldwing cranks can not be turned
CYBORG wrote:My understanding is that the goldwing cranks can not be turned
I've heard this too but never an explanation as to why. If it is a hardness thing then some machine shops could retreat the crank after it was turned.
As to fish's question, it mostly depends on how much material is in the case/crank to start with and how much you would need to remove. You would have to find bearings first and then go from there. And the cost would start to add up.
But, then you have to think about the rod bearings too. Those also take different bearings depending on the code on the crank and the rod. You could again turn the crank journals and resize the big end of the rod. After finding bearings first again. But there goes that cost thing again. Way down the road this may be what we "have" to do.
fish
Post by fish »
Robin I agree with you.
Honda had the best machining facilities in 1975 but I bet if we apply some 2015 CNC & some engine-uity the mains and rods could be turned/resized/line bored to some bearing that IS availiable :-D
In the meantime I think I will go and put a tachometer on WarBird :lol:
Timothy Mark Fisher
Catalina Arizona
Don't bother with the tach. You know you're going to ride it until it quits pulling and then shift, anyways. LOL.
Sometimes the tach just reminds me, when I'm cruising down the hwy, that I still have one more gear. So I'll keep mine
Bugdaddy66
Post by Bugdaddy66 »
Interesting idea, I agree the starting point would be finding bearings to work towards. As far as line boring the case, I see no real issue with it, although there of course would be no specs on how far to safely go before weakening the crank support system. Having line bored many VW cases, I am use to the plethora of bearing sizes available, but don't know of another engine with that kind of bearing availability in Goldwing journal sizes.
Todd Logan (Bugdaddy66)
2003 BMW F650CS (Wife Bike)
2009 BMW R1200RT
jdvorchak
Post by jdvorchak »
I think he is talking about line boring the new bearings to match the crank. Not the other way around.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
Bearings are a composite of material. Removing any of that material would compromise the bearing. In my opinion
jdvorchak
Post by jdvorchak »
Meant to say if the ID of the bearing was correct but the OD of the Babbitt was too big he could line bore the mounts to a certain point to mount the bearing and still fit the crank. I'm not a machinist and I've never tried to track down GL bearings. Seems there are plenty of donor engines with good cases and cranks if yours is no good.
2021 HD Triglide
John
Nope, Fish said, "I wonder if the goldwing crank journals could be turned down to fit some other bearings?". Along with line boring the cases.
salukispeed
Post by salukispeed »
Should we as a group start collecting a bunch of the old shells, if worn but not damaged that could possibly be relined with the copper and soft/Babbit like material. At least they are the correct OD to start?. Or are they different on the OD also since the chart considers both crank and rod/case sizes for selection.
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
fish
Post by fish »
I wonder if bearing shells could be "rebuilt" by electroplating new material on to the bearing surface?
I bet youtube has a video showing how bearings are made.
Timothy Mark Fisher
Catalina Arizona
fish
Post by fish »
Timothy Mark Fisher
Catalina Arizona
Old Fogey
Post by Old Fogey »
I have a crank that at some point has all the journals re-ground to 0.5mm undersize. There is no wear on the crank and only a little on the shells. But I have tried everywhere to find where these shells came from, with no luck.
I posted pics of these some time ago, but at the moment they seem to be lost. I still have the crank and most of the bearings.
