diode-update
JOLLY
My Album: kkjolly2501@verizon.net
diode-update
Post by JOLLY »
can someone tell me what the diode under the seat on a 1986 GL 1200A is for. I have one that is bad , but dont know what its for.
I have done so much with so little for so long, I think I could do anything with nothing at all, in no time flat. My best friend Buddy (my service dog) loves to ride as much as I do.!!! I would hope everyone would use a product called (Ride On) sealant & Balancer, in their tires, because it has saved my life.
1986 GL1200 A (new now driving) 7/1/17
1975 CB 750
1982 CB 900 Custom
1984 GL1200 I restoring
1986 GL1200 A totaled (may be parts bike) as of 6/19/17
Oldboy
Re: diode
Post by Oldboy »
Ok, I'll give it a shot. To start the bike, it must be in neutral, neutral light is on. But the bike will start in gear with the
clutch pulled. With out this diode, the neutral light would flash every time you pulled in the clutch e.g. shifted.
I think that's it.
Cheers...
Just Wing-it
Re: diode
What does the wiring diagram show it is?
jdvorchak
Re: diode
Post by jdvorchak »
If you don't know what it does, how do you know it's bad?
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
JOLLY
Re: diode
Post by JOLLY »
cant seem to find it on the wiring THE DIODE TESTS BAD THE NEUTRAL LIGHT WORKS AS IT SHOULD
1975 CB 750
1982 CB 900 Custom
jdvorchak
Re: diode
Post by jdvorchak »
Sometimes diodes can check bad if you try to check them in "situ" or plugged in. Did you remove at least one wire and perform the diode check? (assuming a 2 wire diode) If more than two wires it could be a bridge rectifier in which case the test procedure is different.
2021 HD Triglide
John
JOLLY
Re: diode
Post by JOLLY »
YES I REMOVED IT TO CHECK IT. I have anther 1986 GL 1200A and it checks out good. there was another post that said something about the neutral switch that just came to mind. I didnt check to see if it would start wile in gear and the clutch is not engaged. I will test that tomorrow. I do thank you all for your posts.
1975 CB 750
1982 CB 900 Custom
JOLLY
DIODE UPDATE
Post by JOLLY »
THIS IS WHAT I HAVE FOUND OUT about THE DIODE UNDER THE SEAT; it keeps the engine from starting when its in gear, unless the clutch is engaged. I am learning slowly, but getting there. THANKS EVERYONE KEVIN.
1975 CB 750
1982 CB 900 Custom
