Ride went well. Just need to pull the shelter back off to install my new electronic flasher that came in the mail. While I am in there I will reroute the clutch and throttle cables a little bit.
The only real issue is the gas and temp gauge don't work at all and they worked perfect before. I double checked the plug but I will have to pull the headlight and go through it again. All of the factory harnesses are intact besides the plug for power to the fairing I cut off. Hmmmmm.
New GL1100 build with Vetter Terraplane Sidecar
- Brass Member
- tallnwise
Re: New GL1100 build with Vetter Terraplane Sidecar
I really like that seat. Can you share name of the Ebay seller?
Thanks,
Dan.
Thanks,
Dan.
1980 GL 1100
- Brass Member
daytrader-07 is the seller. He had some listed buy not what I wanted. He made this custom to my specs. Comes with pan and ready to mount. I had to modify the mount hole about 1/4" but otherwise it fits good.
- tallnwise
Thanks for this info. I really like your build. How much mod did you need to do to install the gl1000 rear fender and cb900 front fender.
Thanks,
Dan.
Thanks,
Dan.
1980 GL 1100
- Brass Member
The rear fender was just shortened in the front to use the factory holes in both the frame and fender. Then it was shortened in the back some. Front fender mounts right up with just a little expansion of the mounting holes.
- tallnwise
Kewl -- thanks for the tips. Have a fun weekend.
1980 GL 1100
- 7 Replies
- 1611 Views
Last post by Sidecar Bob
- 6 Replies
- 640 Views
Last post by gargoyle
