Check your fuses!
Toehead
Check your fuses!
Post by Toehead »
I was doing a pre-ride check and saw my blinkers weren't working. it ended up being the fuse.. Not blown, but cracked . I checked all the others as well. Every single one of my fuses had a fatigue crack. Good thing I found it today, as I have a long ride tomorrow. Check your fuses!
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
todd54219
Re: Check your fuses!
Post by todd54219 »
I had to push my 76 about 1/2 mile when I had a fuse fail. Had an intermittent issue but I could not find the problem. The bike would just die and not start. When ever I was home and could test it, it would not act up. When I pulled the fuses one came out in pieces. Good advice, fuses are cheap and nobody thinks about them until they fail. You would think they would put in a fuse that would last more that a lousy 40 years. :-) lolol lolol lolol
Todd
1976 Yellow GL1000
RB
Post by RB »
Carry spares!!!
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her :(((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
Pony Ruiz
Post by Pony Ruiz »
just because the fuse looks good through the little glass tube might not mean it is.
they can break at each end it seems too. I looked all around for a problem. Fuse was the first thing i checked. Looked good. Finally ended up replacing with new - fixed.
1978GL1000 naked - kinda sadly gone. no bike at the moment.
"The greatest shortcoming of the human race is our inability to understand the exponential function." Albert A. Bartlett.
I had a bunch that looked fine, but you could spin the glass in circles. They weren't connected in the ends.
{ always check them with a meter,....just to be sure
RB
Post by RB »
+1 METER...
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
Pony Ruiz
Post by Pony Ruiz »
how does one check with a meter?
set to resistance i.e. ohms or something....?
"i know nuthink"
Set to ohms.......should be all 0's (short)
KYpondman
Post by KYpondman »
CYBORG wrote:Set to ohms.......should be all 0's (short)
+1, But not all meters will read perfect 0. Short the leads together and whatever reading you see should be the same when you test the fuse.
Claude
That is a better example :lol:
