Getting there!
Wannabe
Zinc Member
Zinc Member
Getting there!
Post by Wannabe »
Pictures up in the Wingman's Lounge (finally) of my ride. Still have a bit to do, but I took if for a quick test run last night. Got to fix that leaky tach cable seal :lol: Sorry for the dark pictures, don't know why I took them in the shade, will take some more in the next few days.
Bandanna
Post by Bandanna »
excellent work wannabe...............
very similar to my friend centrals(member here also) ride.................
take a look at his.............also in lounge..(pg2 bandannas ride wingmans lounge)
it was my old ride+he made it his own+lowered it too. ;) you will see the before on the bottom,and as central has it now on the top............
safe riding.................all
Try
NGW Founder
NGW Founder
Re: Getting there!
Post by Try »
Wannabe wrote:Pictures up in the Wingman's Lounge (finally) of my ride. Still have a bit to do, but I took if for a quick test run last night. Got to fix that leaky tach cable seal :lol: Sorry for the dark pictures, don't know why I took them in the shade, will take some more in the next few days.
Looks very cool Wannabe, keep us posted!!
Try
"84 - GL1200 Standard
anim-cheers1
Fat_Wing
Post by Fat_Wing »
Great job. Man I like these bikes. I like your tail lights. Did you make the short bolagna cut pipes or but them?
FW
Wannabe
Zinc Member
Zinc Member
Post by Wannabe »
They're 'Screaming Eagle', not sure if they were off a Softail or Sporty. Bought for $25 at a swap meet. I had to turn one of the tabs that hold them on around.
Zryder
Post by Zryder »
Nice lookin little hotrod Wannabe , I really like those smaller engine guards , I'd like to change mine to something af about that size . thup I'm sold on those dogbone risers , Are they easy for you to get , If so , how much , I'll send you the money and postage , if you can get them and send to me . In the meentime , I'll try getting them myself , dang , I like them . :-D
BLACKGOLD
My Album: http://www.ngwclub.com/gallery/v/wingmans/BLACKGOLD/
Post by BLACKGOLD »
Looks mean, dude! What application are the shocks from?
Mike
Elvira-1980 GL1100 Custom
Black Betty-2000 HD Electra Glide
"we are on the cutting edge of cocking about" -Richard Hammond
Wannabe
Zinc Member
Zinc Member
Post by Wannabe »
Shocks from Ebay also...they were listed as 11" lowering shocks. I had to remove the inner eye liner from the top rubber to get them to fit (just like I hear you have to do with the Progressives) and had to use a big washer as a spacer, as they are a touch narrower than the stock on the top mount. They were $99 plus shipping. They are made by Forsa with the brand name MDI. Here is a link to the seller's Ebay store, maybe they have more... http://stores.ebay.com/ClassicCyclePart ... viewQQtZkm
Do a search on Ebay for 'dog bone risers' or 'chopper risers' and you will find the dog bones...they come in 6" most commonly, but I kept my eye open for the 4".
Wannabe
Zinc Member
Zinc Member
Post by Wannabe »
I found another set...same ones, same seller. http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=35592
Zryder
Post by Zryder »
With my prgressives I did manage to use that tight inner rubber shim , what I did was cut around the inner rubber that goes on first a shamvfer , and aplied a bit of grease and pressed them on with a C clamp . And if you are short on funds , for a lower shock is take apart the top , unthread the sock shaft from the eye bolt , cut what you need off , rethread that end that was cut thread it back on , But don't forget tpo take the same off the coil also . This is what a fellow had done to his GL 1000 for lower shocks . I did my shocks that way and was told thats how the fellow did with his shocks .
Just two cents Gents :)
BLACKGOLD
Post by BLACKGOLD »
Good idea. unfortunately, my 1100 has air suspension. So I'll have to pony up the cash and buy shocks. Thanks for the info,guys.
Mike
Wannabe
Zinc Member
Zinc Member
Post by Wannabe »
I tried that Zryder, and I didn't feel confident in its safety. Because the top of the coil seats your spring; there is nothing preventing the top of the coil from riding up over your shock tower once this is removed, because you've removed the washer-like spring that the coil itself seats on. I just didn't feel safe with the setup, so I went with the new shocks. The old ones looked rusty anyway 8)
On a different note, I need new front brake lines (lower). Honda wants $54 CDN each for them...ouch! Anyone have suggestions for an alternative? I came across a few used sets on Ebay, but they seem as bad or worse than the ones I have.
Zryder
Post by Zryder »
About those shocks , The fellow replace the spring seats as well he's saying . But as you , I would go new anyways for safety sake thup
Tree
Zinc Member
Zinc Member
Post by Tree »
Zryder wrote: thup I'm sold on those dogbone risers , Are they easy for you to get , If so , how much , I'll send you the money and postage , if you can get them and send to me . In the meentime , I'll try getting them myself , dang , I like them . :-D
Hey Z, my friend got his bonz here, for his CB750 chopper
CYCLE-RE-CYCLE PART II
4 inch x 7/8 inch $12.95
Lowrider Tommy may have them as well
[color=darkblue] Tree
1978 GL1000
Dayton, Tennessee[/color]
[img]http://www.nakedgoldwings.com/forum/images/flags/states/Tennessee.gif[/img]
Wannabe
Zinc Member
Zinc Member
Post by Wannabe »
12.95 is better than I paid. I think I paid $29.00
