double solex pict 30 ??
arie1
Lead Member
Lead Member
Post by arie1 »
has anybody ever tried a double solex 30 pict setup?? One carb above each set of cilinders ??
cheers arno
Re: double solex pict 30 ??
Check your PM's.
