Non-rider building '82 Cafe Racer. Stop laughing.
- My Album: https://www.ngwclub.com/forum/viewtopic ... it=GW+Hobo
Greetings,
I've been in construction for some time and am fairly handy. I've never ridden a motorcycle before (riding classes are scheduled for May) but I've had a bug to try it for years. I finally had my mid-life crisis at 46 last fall when I saw a GW cafe-racer on a city street and had to have one.
In Jan '17, I found an '82 GL1100 Standard with a Hondaline kit in a barn find in Indiana. $500, 21,000+ miles, and hadn't been ridden since about 2002. The engine turned and the frame looked good so I decided to jump in with both feet.
Thanks to sites like this and others, I've begun to build my bike. I took Randakk's "Starting a GL1000 after a long layup" to heart, changed the plugs (see pic of old plugs attached - they look ok, no?), and put in new oil, filter, air filter, checked the fuses, new battery, etc. The fuel tank is a rusty hot mess, so I'm using an auxiliary fuel tank for now until I have time to pull the back tire and the tank.
The starter works and she turns over well but it won't fire. When it turns over, I can feel vibrations in the fuel pump so I'm guessing the pump is sending gas to the carbs/engine, but I'm still going to pull the auxiliary tank fuel line off the fuel pump and put it directly into the carbs/engine to be sure there's no blockage. I'm not smelling gas when I repeatedly try to start it (5 secs on, wait 10 secs and do again) so maybe there is a blockage.
Unfortunately, another issue is that the choke is stuck closed and the throttle won't budge. I've confirmed the cables are free but the linkages on the carb for both seem stuck. Specifically, the choke linkage won't budge at all (not forcing it) and the left side throttle linkage moves some while the right side does not. So I'm guessing there's varnish in the carbs that's keeping the butterflies from opening? I'd like to spray some starter fluid into the carbs to at least get it to fire but that's pointless unless the carb doors are open, correct?
I've searched for "choke stuck closed" and nothing jumped out at me so I'll ask for newbie-mercy in advance since its likely here and I missed it. Any suggestions on how to get the choke/throttle open without removing the carbs for a clean? I'm about to buy the randakk kit anyway but would like to avoid that job until after I get her started and finish with the "long layup" checklist. I've sprayed WD-40 and tried to get things to budge (gently) so I'm suspecting its a carb issue that requires a full clean..??
Final question - I'm putting off changing the timing belts until I get her fired up for the first time...and I can hear Whiskerfish and Roady from here advising me otherwise, ha. My local honda mc dealer (he says he has an '81 GL1100) says don't sweat the belts until after I get it started. He's wrong right?
Thanks all, glad to be here.
Hobo
Hobo
- Day one - tires still held air!
- 20170120_105938.jpg (167.92 KiB) Viewed 371 times
- Breaking it down
- 20170121_181538.jpg (113.08 KiB) Viewed 371 times
- Sans fairing kit
- 20170217_154233.jpg (131.56 KiB) Viewed 371 times
- 15 year old antifreeze
- 20170228_152038.jpg (112.34 KiB) Viewed 371 times
- 15 year old plugs
- 20170219_164754.jpg (50.52 KiB) Viewed 371 times
1982 GL1100 Cafe - Born Naked
2020 October BOM
2020 October BOM
Re: Non-rider building '82 Cafe Racer. Stop laughing.
Welcome from Wisconsin! From the pics, it looks like you've got yourself a keeper. In my humble opinion, if the engine turns over, and you have spark, bite the bullet and pull the carbs for cleaning and rebuild. You could be messing around for quite some time trying to get them unstuck, when you could be rebuilding the carbs. My 2 cents.
Someone here will post a pic of what happens when belt snaps---not pretty. Consider your belts have likely been sitting for years in the same spot. The part that wraps the crank pulleys at a pretty sharp angle, the idlers also will take a set. When you remove the belt, it stays right in the same shape it was on the bike. It's a good idea to change them.
I understand your desire to hear it run, and I did the same thing with my first one. And it went just like Track says. You probably can get gas enough through the carbs to make pops, farts, and bangs, but if your choke linkage is sticking, chances are quite good the bowls are full of varnish, and chances are even greater that your idle jets are plugged. Roady has a good how-to on carbs in Shoptalk.
You can learn from us or like us. Learning from us is easier, believe me. If you do pull the carbs and go through them, you owe it to yourself to also look in the tank and see how bad it is in there. Easiest way is through the fuel sending unit. The filler neck is hard to fit a mirror in to get a look at the sides and top of the tank. The bottom might show only a little debris, but the sides and top usually show the source. Failure to clean the tank, fuel lines, and fuel pump often leads to having to redo those carbs you just cleaned. Ask me how I know??
Take your time, it'll be worth it.
Thanks Eric and Track. The tank is covered in rust, as is the fuel sending unit. And when I say covered, I mean there's rust on top of rust, with a little bit of rusty, syrupy gasoline. When I got the bike, the petcock was open so I imagine old gas may have been able to drain into the carbs..? I'll likely do the electrolytic technique first and then try chemicals on the tank, assuming it hasn't rusted through. Wasn't quite ready to take the rear wheel off yet. But I was really hoping to avoid baptism by carb cleaning. I'm scared of clowns but all them small carb pieces I read about and the few that, if you break them can't be replaced...that sounds like a nightmare for a FNG like me. 10-4 on the belts. Pistons hitting each other scares me too. Not as much as clowns, but still...
GW Hobo
GW Hobo
2020 October BOM
2020 October BOM
- Sugs
Welcome to the site!
_______________________
'79 Honda GL1000 Goldwing
- Moto nut
Welcome from colorado, and it never to late to enjoy the love/hate relationships you'll have with your project....good luck
Proud winner of ngwclub 2017 bike of the year......76 GL1000
Please, start a thread in the project section.
Welcome aboard.
- HOTT
Welcome from Texas!
great find, it can be an awesome machine.
Your patience will pay off big.
Will do, thx.robin1731 wrote:Please, start a thread in the project section.
2020 October BOM
2020 October BOM
- RIP: cookie
Welcome to the 'Wingdom.
If the petcock was left open there may be gas in the crankcase ....
Hi Hobo, welcome to NGW, nice bike!
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
- 10 Replies
- 1669 Views
Last post by sunnbobb
- 20 Replies
- 3010 Views
Last post by ianstaley
- 1 Replies
- 683 Views
Last post by Sidecar Bob
- 772 Views
Last post by rcmatt007
- 50 Replies
- 2941 Views
Last post by Beav's
