Fan switch solution..
After ordering the switch from rock auto like others did only to find out the thread was to small..I've been doing some digging along with a friend at our local NAPA store.
This is what we've found.
This switch has the required 18mm x 1.5 thread https://www.summitracing.com/int/parts/ ... /overview/
You can order a new connector off fleabay.
http://www.ebay.com/itm/BRAND-NEW-Engin ... 1422704687
I ordered the switch and I'm going to hopefully get a used connector from a local salvage yard. I will keep everyone posted on if it works.
Re: Fan switch solution..
Let us know about this. If it is good we will add it to the cross over parts list.
will do WF.
well..the switch fits.
however..unless you live in the US..the ebay seller won't ship the connector to you.
It apparently fits a broad range of honda's and acura's but going through the various models on rock auto I haven't been able to find that style connector..
Apparently the seller hasn't been doing it right. Ebay now has an address in Kentucky to send any and all items that go to overseas addresses. It goes there first then ebay gets it to the buyer. It works very well.
- Goboy
- My Album: https://www.ngwclub.com/forum/viewtopic ... 30&t=60678
5speed, does the switch use a different style connector or is your's damaged?
I see why your bike is not running!
You're too small to ride a hog Billy!
Mike
1978 GL1000
Previous bikes: 05 Yamaha FJR 1300, 79 Suzuki GS 1000, 75 Yamaha XS 650, 73 Kawasaki S2 350
Mike
1978 GL1000
it is a completely different style connector. my switch was bad as a previous owner bypassed it.Goboy wrote:5speed, does the switch use a different style connector or is your's damaged?
I am not a fan of bypassing anything as a permanent fix so..here I am. lol
There is a good fix for the fan switch in ShopTalk.
read thru all those. the switch I have is the same as the Borg Warner # TFS600.
I took my old switch apart and the "needle" wasn't stuck..so I'm assuming it is fubar.
another update...finally received the connector today.
The good news..it works like a charm.
The bad news..there is no part number for it.
- tlbranth
This it? https://www.ebay.com/i/112302951871?chn=ps&dispItem=1
How about this?
https://www.acuraautomotiveparts.org/au ... sor-1-scat
How about this?
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
It sure looks like it. I will double check the orientation of the locking clip and "key" before I say for sure.tlbranth wrote:This it? https://www.ebay.com/i/112302951871?chn=ps&dispItem=1
How about this?
the price differences on e-bay are crazy..who would pay $117 for a connector.
here it is..and now we know what it's for.
http://www.ebay.com/itm/IAT-INTAKE-AIR- ... 2302951871IAT-INTAKE-AIR-TEMPERATURE-PLUG-PIGTAIL-SENSOR-Plug-for-INTEGRA-HONDA-CIVIC
- tlbranth
Moderators: how about adding this to the crossover parts list?
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- Lead Member
This is very helpful for my situation. Got stuck in gridlock traffic and the temp needle started to rise a bit high. I had to pull over so that an overheating situation didn't arise, and that's when I noticed that the fan wasn't on. I pushed on the rubber boot over the temp sensor connector and the fan started up. It would only stay on as long as I kept pressure on it. After a while, I got it to work, more or less, but it's very sporadic. The problem really needs to be dealt with. Parts have been ordered, Thanks for the info!
- 11 Replies
- 1852 Views
Last post by alwing17
- 17 Replies
- 2703 Views
Last post by 5speed
- 1509 Views
Last post by Track T 2411
- 7 Replies
- 1335 Views
Last post by 5speed
