Changing a 78 motor into a 75
OhioBill
My Album: http://www.ngwclub.com/gallery/v/wingmans/OhioBill
Post by OhioBill »
Are these the steps necessary to change 78 Goldwing motor into a 1975 motor. It seems rather straight forward but I want to make sure.
1.Replace 78 carb set with 75 carb set.
2. Replace cams or do you have to change the heads as well? Can I measure the bearing wear to make sure the cam bearings are within spec?
3. Change the mechanical advance unit
4. Mark new timing marks on crank to correspond with the 75 timing specifications.
Have I missed anything?
OhioBill
Retired and Loving it.
1979 Black (to be restored)
1979 Blue (Sold)
1993 blue 1500 Sold
1976 Restoring
Re: Changing a 78 motor into a 75
OhioBill wrote:Are these the steps necessary to change 78 Goldwing motor into a 1975 motor. It seems rather straight forward but I want to make sure.
1.Replace 78 carb set with 75 carb set.yes
2. Replace cams or do you have to change the heads as well?just the cams, rocker arms to match the cams if you can Can I measure the bearing wear to make sure the cam bearings are within spec?there are no cam bearings
3. Change the mechanical advance unityes, to match the cams
4. Mark new timing marks on crank to correspond with the 75 timing specifications.yes
Toehead
Post by Toehead »
+ 1 on above.
Also, keep the 78 heads. They have better oil grooves in the cam "bearing" surface. I've noticed there is much less scuffing of this surface on the later heads vs. the early ones.
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
