Timing belt tensioner roller replacement
bottona
Zinc Member
Zinc Member
Post by bottona »
Thanks to the following: (I am sure I’m forgetting someone, sorry)
Sandiegobrass: for original fantastic research!
Gltriker: for the most attractive idea, and least work and tools.
Ericheath: for the original photo, that I forgot too!
I am rebuilding a 76 LTD, and noticed I needed some new tensioner rollers, so I went thru your wonderful website and found a lot of really good research, Thank you all so very much! I have and want to keep the heat shields and spacer plate behind the bracket. So when I stumbled on gltriker’s great write-up, I thought, this will work real nicely, Thank you gltriker!
Anyway, here is my write up, hope it helps somebody out there.
Tools needed: Drill Press, 1/2" drill bit, 7/8” diameter 6-fluted 90 degree countersink bit, handheld grinder with thin cut-off wheel attached, 1/2” wood chisel, punch.
Roller and fasteners needed: (2) Gates T42015 idler rollers, (2) 10mm x 30mm lg 10.9 flat head screws, (2) 10mm nylon lock nuts.
Remove both roller brackets (photo by Ericheath).
Use a 1/2” drill bit in a drill press and remove pressed section (hex shape) until drill bit bottoms out in the existing stud. Notice this photo is actually incorrect, I forgot to take a photo of the drilling on the countersunk side of the bracket.
Use a wood chisel to pry idler away from bracket as shown. To reduce any bending of the bracket, Use the wood chisel because the ramp gives a good pry angle, the sharp end should not hit hard against the idler shaft.
Punch the idler shaft out of the bracket the rest of the way.
HF has a 90 degree chamfer tool, cheap, but looked like it wouldn’t cut metal. So call your local machine shop retailer, and find this chamfer tool. $15.00 and made in the states. 1/2" shank so it will work in a small drill press. 90 degree is the standard countersink angle for metric fasteners (as compared to 82 degrees for SAE countersunk screws).
More to come...
Cheers, Albert
bottona
Zinc Member
Zinc Member
Post by bottona »
To continue...
Set your drill press speed to its slowest setting, then cut the chamfer in the bracket, cutting the chamfer in the same place and on the same side as the original chamfer. Cut down deep enough to make the flat head screw sit just under the top surface of the bracket. Use some cutting fluid if you have it about. Slow going at the end of the cut.
This is the countersunk hole you should end up with.
Chamfer finished in both pieces, notice they are the same, not left and right handed. That happens at engine mounting time. Smart design for commonality of parts.
More to come...
Cheers, Albert
bottona
Zinc Member
Zinc Member
Post by bottona »
To continue...
Gltriker noted that the conical portion of the flat head screw will be too deep (THANK YOU). So lightly chuck up the screw in your drill press, then carefully cut excess depth out using a hand held grinder with a thin cut-off wheel. Refer to drawing below:
Drawing showing material to remove from flat head screw.
More to come...
Cheers, Albert
bottona
Zinc Member
Zinc Member
Post by bottona »
To continue...
Loose parts ready to assemble
Front view of assembled rollers
Back view of assembled rollers.
Hope this helps someone out there. This was my exercise to see what I could do in my garage with simple tools.
Cheers, Albert
Gowing
Re: Timing belt tensioner roller replacement
Post by Gowing »
Really great tutorial bottona, I think it's the best I've read! Thank you.
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
Rednaxs60
Post by Rednaxs60 »
Great job. Did this as well. Way less expensive then buying new from Honda.
Cheers
Ernest
1985 GL1200 Limited Edition
2014 Can-Am Spyder RT LE
2008 GL1800 (sold)
Toehead
Post by Toehead »
Nice finished product! I like that better than what I did, which was to use a dome head screw that required me to leave out the heat shield. Your way is much slicker.
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
WELL DONE. The best documentation of all methods I've seen, too! :oldies
If I'd had a good drill press, myself, this would have been a perfect alternative to undercut the screws' taper without getting my perfectionist machinist buddy involved, too. tumb2
Cliff ;) )
bottona
Zinc Member
Zinc Member
Post by bottona »
Thx for the compliments everyone, drawings are easy for me as it's my job in real life.
My buddy has a lathe, but I thought I'd like to try it with the tools at hand.
Cheers, Albert
canuckxxx
Post by canuckxxx »
Is there a car that those Gates T42015 idler rollers fit?
1982 GL1100 Naked
bottona
Zinc Member
Zinc Member
Post by bottona »
1997 to 2008 Kia and hyundai 1.8L, per the earlier research done by sandiegobrass (Thank you).
Cheers, Albert
canuckxxx
Post by canuckxxx »
OK thanks
1982 GL1100 Naked
