I'm replacing the clutch cable and I think I have where it figured out as it enters the frame down to the clutch. What I don't fully understand is where the cable goes out from the lever as it crosses the front of the fork area. I've seen the drawing in the Service Manual but does it go just behind the headlight? between where the gauges bolt on by the front of the stem? etc.
I've looked for a good picture showing how it should thread its way from the lever to the frame but can't find one. Anybody got a good picture(s) of his area?
Thanks
https://ngwclub.com/forum/viewtopic.php ... 81#p828672
Routing of Clutch Cable from Lever on 1977
2001 GL1800 Illusion Red
Re: Routing of Clutch Cable from Lever on 1977
Thanks Whiskerfish! My clutch cable is routed there now but it sticks up to high and kind of blocks the Tach. The more I looked at the cable it seemed to tight in the hole beside the choke so I thought it must be routed wrong. The clutch is stiff so I thought I would put a new clutch cable on. I'm now going back to replace the front fender, Tach. and Speedo, along with the Clutch cable so I figured I better confirm everything.
Your name showed in a lot of the clutch cable postings so you probably get tired of people asking, then roll your eyes and say "Not again!" Thanks again Master Chief I appreciate it!!
Dave Mc.
Dave Mc.
- OhioBill
- My Album: http://www.ngwclub.com/gallery/v/wingmans/OhioBill
You might also look at how Puffy routed his clutch cable. His way made a lot of sense as it kept bends to a minimum.
OhioBill
Retired and Loving it.
1979 Black (to be restored)
1979 Blue (Sold)
1993 blue 1500 Sold
1976 Restoring
1979 Blue (Sold)
1993 blue 1500 Sold
1976 Restoring
Yea Puffy's way was nice. I think he had a couple of custom standoffs made for it though?
- 11 Replies
- 1025 Views
Last post by 77Gowing
- 1 Replies
- 383 Views
Last post by warhead_71
- 438 Views
Last post by EdK
- 4 Replies
- 802 Views
Last post by transitman
