Well, it takes a lot to surprise me anymore and amazingly there isn't much to keep these old gals down. I am wrapping up my Dumpster project (Goldie, the Dumpster G(a)L ) in the next few days so while I am waiting on the last of the parts, I dragged this '85 Full Dresser into the shop and started the disassembly. I wanted to do a compression check but the starter doesn't work and since it had already been converted to an external alternator, the stator was probably (?) bad. Fortunately I have a nice 1200 engine setting by waiting for a good use. Hopefully this will be a good use.
My plan is to install the engine, swing arm, and front end in an 1100 frame. Why? you ask and with good reason. Well, because I have a title for the 1100 and not the 1200. Plus I can use a conventional shelter cover for the 1100 since finding a good one for the 1200 frame is most likely fantasy.
I will most likely have a professional go through the carbs but I like to open them up and clean them a bit before I send them off, that way I have an idea if anything is broken or missing as is sometimes the case. Like maybe this case. I don't see anything broken but I am pretty sure there are some parts missing. And my my they are a mess. I don't think a battery would have gotten this one going!
And so the adventure begins, will keep you posted, just in case anyone is interested.
