Hi Guys,
I'm in the process of changing my water pump (1982 interstate).
While reassembly the front cover, I tested the neutral switch and it was ok.
Now that the cover is back on, being hold by 2 bolts only, the neutral light comes on in neutral AND in 1st gear.
I'm guessing I'm a bit out of alignment?
I will remove the cover tonight and turn the actuator a bit to see if I can make the light come up only in neutral.
Would you see any other reasons the light would act like this?
Cheers
neutral switch, light in 1st gear
- Steevensi
The Black Bike
http://www.ngwclub.com/forum/viewtopic.php?f=30&t=59312
1982 GL 1100
1980 GL 1100 to be fix
1983 Honda Nighthawk 650 sold
1980 Suzuki A100
1974 Suzuki TS 250 sold
1992 Yamaha RT 180 sold
1976 Honda CB125 sold
2002 Suzuki Katana 750 sold
1982 Suzuki GS750 in boxes
1982 GL 1100
1980 Suzuki A100
- Steevensi
Re: neutral switch, light in 1st gear
Moreover, when installing the waterpump into the cover, I used the new crush washers and torque them to 9#. However, they crushed a lot more than I expected, meaning that they become larger then they were. Can you confirm if they are supposed to stretch that much when torking them?
I think the washers I removed were not stretched. But maybe the PO did not use crushed washers if he changed the water pump in the past.
The Black Bike
1982 GL 1100
1980 Suzuki A100
1982 GL 1100
1980 Suzuki A100
- 15 Replies
- 1014 Views
Last post by pidjones
- 574 Views
Last post by flyday58
- 19 Replies
- 1588 Views
Last post by Whiskerfish
- 3 Replies
- 282 Views
Last post by Track T 2411
- 4 Replies
- 228 Views
Last post by trat
