triple tree nut removal
- gdonlo04
what type of wrench/socket is needed to remove the center nut for 1978 gl 1000. it is round nut with 4 cuts in it.
Re: triple tree nut removal
Special socket. Most make one out of a cheap normal socket
Some say these work for a variety of Wing specialty fasteners.
- tlbranth
I made mine from a length of pipe
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
I just used a drift and hammer.... tap tap tap
- Sugs
+1 That's how I do it as well.rcmatt007 wrote:I just used a drift and hammer.... tap tap tap
Y
_______________________
'79 Honda GL1000 Goldwing
- tlbranth
Probably. With a tool, though, you can get a better feel for tightness. On my GL1500, there's a sequence of torques and maneuvers necessary to get it right. Can't do that with a punch. On the older bikes, it's more by feel.Sugs wrote:+1 That's how I do it as well.rcmatt007 wrote:I just used a drift and hammer.... tap tap tap
You guys that actually make a tool have too much time on your hands...
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
The FSM does provide a sequence for installing the nut properly... Just saying...tlbranth wrote:Probably. With a tool, though, you can get a better feel for tightness. On my GL1500, there's a sequence of torques and maneuvers necessary to get it right. Can't do that with a punch. On the older bikes, it's more by feel.Sugs wrote:+1 That's how I do it as well.rcmatt007 wrote:I just used a drift and hammer.... tap tap tap
And anyone who only has a hammer and chisel in their tool box has a machine with rounded heads on nuts and bolts. I have seen why to many triple tree fasteners that are so chewed up the proper tool won't even fit it. Ya, I'm a tool whore. But using the proper tool for the job, makes the job more enjoyable. The fork nut is probable the most abused of any on our bikes. I've thrown away, and replaced any number of one that had been hammered on. The few minutes it takes to make a proper tool is better spent then the time it takes to remove one with a hammer. And then there is the torque issue. How do you get the proper torque with a hammer?
- 6 Replies
- 436 Views
Last post by rcmatt007
- 0 Replies
- 396 Views
Last post by wayneperry
- 6 Replies
- 803 Views
Last post by low-side
- 28 Replies
- 3808 Views
Last post by bladredhead
- 9 Replies
- 424 Views
Last post by Shadowjack
