Intake Manifold Rubbers
I am replacing the rubbers on the intake manifold. The old ones are stuck on pretty tight and I am having to cut them off. Were these glued on originally or has the rubber simply become stuck on over time?
- chewy999
Re: Intake Manifold Rubbers
Why are you replacing the rubbers, and what with? I believe they are bonded to the manifolds and as you say have to be cut off. I have seen 'replacement' rubbers that are fixed with something like jubilee clips, but imho they don't look great.
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
- andorragl
Take a look at this thread https://www.ngwclub.com/forum/viewtopic ... 62#p727962
1976 GL1000 LTD
1995 VT1100C2 ACE
2003 CB1300F1 SUPER FOUR
1995 VT1100C2 ACE
I believe they were originally installed with a vulcanizing process to bond them to the runner. Me I would buy a used set of runners of flea bay or such.
- BlueThunder
Replace with:
http://jbmindustries.com/Goldwing.html
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
The old one were leaking. I have bought these
I have cut the old ones off and cleaned with a wire brush. Yes, the new ones don't look as good, but they are air thight.
I installed a set of JBM carb sockets that someone on another forum gave me (with a set of powder coated intake runners too!!) on mine when I installed the new engine. I think they look OK
- chewy999
They do look better than I remember, especially with all the other bits and pieces fitted. As long as they do the job............
Previous Rides,
Current bikes
Current bikes
Very clean machine, Bob. Could I briefly/slightly derail this thread and ask about the dual fuel filter config you've installed? Two tanks?Sidecar Bob wrote:I installed a set of JBM carb sockets that someone on another forum gave me (with a set of powder coated intake runners too!!) on mine when I installed the new engine. I think they look OK
The bike's original tank and the auxiliary tank on the sidecar (I usually use up the aux tank first because it has no fuel gauge and then switch to the main tank).
- UKFan4Sure!
I'm sorry, but that just looks awful.BlueThunder wrote:Replace with:
79 GL1000 Custom Cruiser
95 BMW K1100rs
95 BMW K1100rs
I'm not a fan of the look eather
And $100 for a set makes it more painful. I would go with a used set off fleabay.
-P.
-P.
I guess they look better than ones that are cracked, but I am with cyborg on the look
I thought the same but now that they are on the bike all I notice is that they look fresh & new and have shiny new stainless clamps (Norma-Torro 9mm wide, 40-60mm dia. about $2 each). And that (without adjusting the balance from the old engine) I can actually use the idle screw to adjust the idle (it was backed out to where it didn't touch the stop before).
I think that's a pretty good compromise compared to spending money for 35 year old used rubber parts that may or may not leak or begin to leak in the near future.
- 14 Replies
- 1276 Views
Last post by dontwantapickle
- 3 Replies
- 621 Views
Last post by robin1731
- 23 Replies
- 2067 Views
- 3 Replies
- 515 Views
Last post by Whiskerfish
