1975 GL1000 project, first Goldwing
Re: 1975 GL1000 project, first Goldwing
no.. tail up is reserve. tail down is on
Well that would explain how I drove through the reserve...rcmatt007 wrote:no.. tail up is reserve. tail down is on
1975 Honda Goldwing GL1000 (café project, started Oct 2018)
1978 Honda CB400T Hawk II (son's project)
1980 Honda CB750C Café
1986 Honda Goldwing GL1200 stock dresser
how you drew it is reserve. How the actual lever is positioned is off. If the lever was pointing down, it would be the normal, main tank on. With the lever in the pointed down position the fuel will flow from the main supply of the tank. When it runsout in that position, you can move the lever to the straight up position, and have a reserve of about a gallon.
So the lever is the "pointer"... that's why I'm confused and I'm sure I'm confusing everyone else. Because the lever points away from "OFF" so I assumed that to go to "ON" you have to point it away from "ON" which is lever upCYBORG wrote:how you drew it is reserve. How the actual lever is positioned is off. If the lever was pointing down, it would be the normal, main tank on. With the lever in the pointed down position the fuel will flow from the main supply of the tank. When it runsout in that position, you can move the lever to the straight up position, and have a reserve of about a gallon.
I think the confusion is which end of the pointer we are talking about. The handle, the part you hold on to to change the position, is the pointer for this conversation. In your picture, the pointer is pointing horizonally, tward the front of the bike. That is the OFF position. Pointer down is main tank ON. Pointer up, is reserve portion of the tank ONbrewer013 wrote:So the lever is the "pointer"... that's why I'm confused and I'm sure I'm confusing everyone else. Because the lever points away from "OFF" so I assumed that to go to "ON" you have to point it away from "ON" which is lever upCYBORG wrote:how you drew it is reserve. How the actual lever is positioned is off. If the lever was pointing down, it would be the normal, main tank on. With the lever in the pointed down position the fuel will flow from the main supply of the tank. When it runsout in that position, you can move the lever to the straight up position, and have a reserve of about a gallon.
Yes I'm tracking you on what the pointer is for this conversation but can you see my point that it doesnt point to OFF when in the OFF position but then points to ON and RES when you want to select them?CYBORG wrote:I think the confusion is which end of the pointer we are talking about. The handle, the part you hold on to to change the position, is the pointer for this conversation. In your picture, the pointer is pointing horizonally, tward the front of the bike. That is the OFF position. Pointer down is main tank ON. Pointer up, is reserve portion of the tank ONbrewer013 wrote:So the lever is the "pointer"... that's why I'm confused and I'm sure I'm confusing everyone else. Because the lever points away from "OFF" so I assumed that to go to "ON" you have to point it away from "ON" which is lever upCYBORG wrote:how you drew it is reserve. How the actual lever is positioned is off. If the lever was pointing down, it would be the normal, main tank on. With the lever in the pointed down position the fuel will flow from the main supply of the tank. When it runsout in that position, you can move the lever to the straight up position, and have a reserve of about a gallon.
I might suggest you look at the shop manual for pictures that show how it works.
or take my word that how I explained it, is the way it works. I have had my GL1000 over 30 years, and THATS how it works
I gotcha. Not arguing or questioning you. I have the Clymer manual and it's of no help in this regard. Just trying to explain why the operation doesnt make sence to me and how it led me to the confusionCYBORG wrote:I might suggest you look at the shop manual for pictures that show how it works.
I just looked at the fuel valve on my 1000. I see why you might be confused. Forget what the lettering on the valve says. For one, it assumes the pointer is the opposite end of the lever, as we have explained it. Simplest way to look at it, and to use the lever while riding, is as we have explained it
Make it easy. Full counter clockwise is on. Full clockwise is reserve.
So look at the queen video for crazy little thing called love. The petcock is on reserve
I think there’s an itty bitty arrow on the handle.
Ok... I just got home and was able to take a look and confirm that I am an idiot. I envisioned in my mind that the OFF is stamped on the right/rear part of the petcock and it's not... it's on the front so of course everyone's explanations are correct and surely I can understand your frustration at my moronicy, especially CYBORG.
I believe I had confused myself with the extra petcock I have from a 79 which is opposite. I'm going to fill up again and verify the reserve since I've been running it backwards.
My apologies... moving forward. Haha.
no harm … no foul
- Zinc Member
There are arrows on both sides of my 82's petcock control. Maybe they weren't on the earlier bikes.ericheath wrote:I think there’s an itty bitty arrow on the handle.
For me, it's always been a question of remembering to switch back to primary when I re-fuel on reserve. On one long trip across the desert, I was thrilled with the range I was getting until I reached down to check. Sure enough, I was on reserve already. I slowed way down, because the next gas station was still a ways off. I made it to the off ramp, and the bike died at the top of the overpass. I coasted down into the gas station and filled the tank. I was very grateful. It was about 110F+, and would have been miserable pushing or hiking.
82 GL1100 Standard 44k miles 83 wheels & forks
- 17 Replies
- 1494 Views
Last post by heDONist
- 102 Replies
- 7881 Views
Last post by leonardhcross
- 16 Replies
- 1485 Views
Last post by BrooksGL1000
