https://ngwclub.com/forum/viewtopic.php ... 81#p828672
80 GL 1100
JohnBaxter
80 GL 1100
Post by JohnBaxter »
What is the best way to turn the motor on my 1100.
I suspect the engine is seized.
When the Power of Love
Overcomes the Love of Power,
Then and ONLY then
Will we find peace.
Re: 80 GL 1100
The simplest way is to remove the plug on the back of the stator housing and use a ratchet and socket on the stator bolt inside. Be sure to only turn it clockwise, as you otherwise run the risk of loosening the stator bolt. Other methods include putting the bike on the center stand, in gear, and turning the rear wheel, or removing the belt covers and turning the crank shaft bolt (again, clockwise). Using the crankshaft bolt probably allows applying the most torque, if you're trying to break the engine free...
chewy999
Re: 80 GL 1100
Post by chewy999 »
It will also help if you take the spark plugs out.
anim-cheers1 anim-cheers1
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
JohnBaxter
Re: 80 GL 1100
That's my next step, timing covers are off and I am feeling the urge to remove the right head, as it appears that the timing belt for the right side looks almost new, and the other side looks original.
Then and ONLY then
Will we find peace.
